Results 1 to 17 of 17
Thread: VS leaking coolant...
    VS II exec.
    Oct 2008
    tarneit / torquay
    Default VS leaking coolant...
    so i FINALLY had my VS running right and then i discovered its leaking coolant... a couple weeks ago it like pretty much overheated cuz it was out of coolant, but i didn't really think much of it... just flushed it, changed the thermostat and put new coolant in.... then the other day i realised it's leaking... but it doesn't look like its coming from the radiator..
    for what it's worth, i had an accident a couple of months ago that did a fair amount of damage to my front end.... but i haven't had any problems til now
    any ideas??
    vnss
    Jan 2005
    s.e melb
    get it pressure tested and find out where the leak is and fix the problem
    vy
    Mar 2009
    could be leaking radiator or heater hoses or could be the water pump seal. have to look abit harder should be able to see where it is coming from but these are a few places to check!
    VR Caprice
    Dec 2005
    There should be traces of a whitish colour from where its leaking, check around all hoses and the water pump, get under the car and look for the whitish colour. If you cant see anything get a pressure test from a radiator shop.
    VS l67 statesman
    Dec 2008
    Did you bleed the system? it can cause the overflow to dump coolant if you didnt, also if its coming out above your gearbox it could be a heater core problem
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    If you overheated it there's a possibility you may have done and intake manifold gasket which is not the worst thing in the world. Or possibly a head gasket. Are you seeing any signs of oil under the radiator cap or milky oil?
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    Vy Sv8
    Jun 2009
    If I were you i would check the plastic top part of the radiator, your hoses and your heater tap.
    Most heater taps become brittle and break apart. Check your hose clamps arent coming undone...
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    As said, get it pressure tested and the leak will reveal itself pretty quick smart.
    VS II exec.
    Oct 2008
    tarneit / torquay
    it doesnt have oil or anything in the coolant... everything runs fine............until its leaked all the coolant LOL...
    and yeah, i bled it when i flushed it last... i'd get my ass kicked if i didn't lol..
    i'll try and check all the hoses for white stuff tomorrow... *dodgy*
    cant do too much... baby bump gets in the way these days ay
    VS Berlina S1 V6
    Jul 2009
    I had a very similar problem, turned out to be a combonation of both the water pump housing and the heater hose assembally. Everything gets pretty brittle after 14 odd years.
    VX L67, ln106 hilux, xr600r
    Jun 2009
    qld
    VS exec
    Jun 2009
    bong from the gong
    you can get a uv dye to add to your coolant and then use a uv light to find the source of the leak
    VS II exec.
    Oct 2008
    tarneit / torquay
    uv dye??? that sounds cool as lol...
    i checked to see if i could see where the leak was coming from yesterday, and discovered that there wasn't a puddle of coolant under my car.. but i had plenty of coolant in the radiator and overflow.... but then this morning there was a puddle....??
    WTF is going on!? lol...
    im about to give up and get ripped off by a mechanic lol
  15. #15
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Fill up your Radiator, take it for a run until the hoses get pressurized, get a thick piece of clothing or rag and give all of your hoses a squeeze at both ends. It sounds like you just have a split in one of your hoses somewhere. Normally its where the clamp is, so you can't see it unless you give it a squeeze when they are all Pressurized.
    Mumbo Man
  16. #16
    vr with ecotec
    May 2009
    just an idea i had a very simular problem with my vs ecotec and it wasn't till i had a gearbox blow up that i found my water problem. once the gearbox is removed and you remove the flywheel there is a plateon the rear of the block which holds the rear main seal and also covers water jackets and found that if your car has got really hot the first thing to cause a problem is this plate as it worps and wont seal. i bought a new one from holden and just to give you an idea it cost me $140 to buy and it come with a new plate new rear main seal 12 bolts and 12 special seals for the bolts. so if you get th chance to get under the car or get some else to check around the bellhousing and in between the sump and gearbox as thats where it will leak
  17. #17
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Heater core, heater hoses, radiator hoses, cracked radiator, welsh plugs (most likely not if you are losing coolant fast), or if you are filling up your resevoir to almost full (way above the "max" mark) it will dump coolant (overflow), also could be the inlet manifold gasket.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
  1. Coolant leaking from something...
    By LightningVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2008, 12:59 AM
  2. leaking coolant
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2008, 10:11 PM
  3. Mystery of the leaking coolant...
    By Rickman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 02:06 PM
  4. Leaking Coolant
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2006, 08:49 PM
  5. Coolant Leaking Help Vn
    By WeBsTeR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2006, 08:18 PM
Tags for this Thread
