Results 1 to 3 of 3
Thread: Floor vents always blow hot air?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Exclamation Floor vents always blow hot air?
    Thinking this may be my heater tap stuck on, caused by that vacuum switch. Wondering if anyone can confirm this as I need it fixed.
    If i turn it to cold and hit the AC switch, it will blow cold air conditioned air, but the centre console at leg height remains hot near where the heating pipe sits. The heating pipe is always hot, and if I give the engine a squirt it gets REALLY hot. Any air conditioning experts out there? otherwise im just going to have to take it to NATBAD.
    VS exec
    Jun 2009
    bong from the gong
    Sounds like the heater tap is staying open, change it for a new one also flush and change your coolant at the same time
    VZ SV6
    Oct 2008
    Newcastle NSW
    The heater taps do play up a bit it seems, they are only made of plastic. The other end of the spectrum is when they crack up due to age and piss coolant out everywhere (leading to mass coolant loss, overheating etc)
    When I did my engine change, I was replacing it anyway for convenience sake (easier with the motor out, save doing it later when it blows) and it pretty much crumbled under our hands when it was touched.
  1. Will this blow my speakers?
    By owen18 in forum Car Audio
    Last Post: 28-04-2009, 01:32 AM
  2. Help vn 5.0 blow by
    By calais_8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 11:24 PM
  3. How to blow 5k on a VN S1?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2007, 11:07 PM
  4. will this blow my sub
    By lieos in forum Car Audio
    Last Post: 27-08-2006, 03:29 PM
  5. Water coming out of floor vents
    By Phiness1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2004, 08:57 PM
