Results 1 to 10 of 10
Thread: vt ecotec into a vs ute
    1996 VS COMMY UTE SER II
    Jun 2009
    gatton
    Default vt ecotec into a vs ute
    hi all im new to this fourm im just wondering if anyone can help me i have to change my engine in my vs due to being old and sad ( 420,00kms) and had a hard life but i picked up a vt engine from a sedan i got the complete engin and bolt ons the auto the engine wirring loom the ecu the bcm ect... just wonderin i want to use the comp and harness from the vt just wondering has anyone done it befor if how did you do it or if anyone knows how i can go about it would be great anyway hope to hear soon
    CHEERS RUMBUCK
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Keep the VS ECU and BCM, the engine is a straight swap. The injectors were different though, the VS ones being a slightly higher pressure or volume, one or the other. I think it is volume.
    Visit my Facebook page
    Jun 2009
    gatton
    i mainley want to use the vt gear cause the comp is chipped and the wiring harness is a bit dodgy on the ute and the vt has 2 thermo fans on the radator that i want to use where as mine is only 1
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Not 100% on swapping the ECU's. Should work though. Don't use the VT BCM though, yours will be fine.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    you have 2 options.
    1. drop in your new VT engine, and wire it up with the VS wiring, tap another temp sender in the manifold. use ur existing VS header manifold not the VT one (different shape coz VT has more room in the bay). n thats just about it. workout from the VT loom the wiring of the thermos, and duplicate it using ur original VS loom. I would do this first ensuring that it starts and runs before Plugging in ur 'chipped' chip in VS ecu. Much easier and cheaper.
    Dont stress bout the injector pressure its controlled by the regulator which is all part of the VT fuel rail. and NAAF is right the VT ones flow 1cc less but have a better spray pattern. I have a VT engine in my VS and this was the process i followed. i kept my A/C compressor and didnt use the VT one, no regassing needed.
    2. strip your engine bay wiring and replace it with the VT one. u'll have to get a VT manual and a VS manual to compare the wiring at the ECU and any other wiring from/to the ecu (ie from the bcm) to ensure it all matches fine.
    There has been a couple threads in this section about doing this same thing, and a heap of info that may be missed will be in there, do a quick search for more info
    Jun 2009
    gatton
    Quote Originally Posted by ephect View Post
    will a vt chip thats a " RACEBITS" brand part number " VTV6A98" fit into a vs ecu?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    no idea, im guessing it should. but mate, thats the last thing on ur mind, u want ur car running again and reliable, yes?
    Jun 2009
    gatton
    im doing it for a project i got the lot at a good price i got a reliable car that im not going to mention on this forum im looking for abit more power and im hoping i can sort out a gas problem with the vt gear
    Jun 2009
    gatton
    b4 i starter to rip the engin apart i swaped the chip over and it would start but die in the ass after the first fire i have no idea any suggestions but yeah decided to go with the long motor swap but is it easyer to swap the valley then to tap the hole in ??? and is there any internal differences between the vs eco and the vt eco??
    CHEERS RUMBUCK
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the VS & VT motors are both the same internally. and really its up to you if u wanna swap valleys i would think its easier to tap it, as u dont have to crack the manifold and then have to replace the valley gaskets. just keep the fuel rail and injectors with each engines manifold.
  1. whats better ecotec or 3.8L (not ecotec)
    By john_mete in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-08-2009, 12:45 PM
  2. Pre-Ecotec with Ecotec Performance Upgrades
    By JA2Z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2009, 10:06 AM
  3. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  4. WTB: RECO VS ECOTEC or ECOTEC STROKER
    By Cursed CX8 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-09-2008, 12:15 AM
  5. Ecotec into VR..
    By Ash81x in forum V6 Development And Modification
    Last Post: 02-09-2005, 12:15 PM
