Results 1 to 4 of 4
Thread: fried vs
    VS Executive
    Jul 2009
    Default fried vs
    hey i think i may have connected my battery the wrong way around on my vs , would this have fried my computer and how hard is it to fix? could it just be the main fuse??
    VS executive
    Jun 2009
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    you may have fried a few fuses..
    as pillzor, what happend when you corrected this?
    VS 97 V6 Exec & most resently VL V8 calais
    Jan 2011
    Perth,W.A
    i've only just yesterday posted the same QUESTION (only my M8 did the honours of connecting the battery arse-about 4 me)>>> & after thinking the same 'O.M.(f***en)G' THE COMPUTERS FRIED i jumped online & got the cool,calm reply of HAVE U CHECKED your fusible links and other fuseS ??? my alt was cooked so i replaced that,then got the workshop bible out and traced back from the battery 2 the fusible links (MAIN one was blown) to the alt then along to find the cruise control was on the same line & then checked out the under the dash to find the CRUISE CONTROL & HAZARD light fuses were melted!!! LEARNING SOMETHING EVERY DAY but i haven't replaced any of the fuses yet but will let u know the FINAL outcome once i do... DID YOUR ALT BURN-OUT with smoke & all??? did the cruise control SPEED setting light stay on after u hooked the battery up da wrong way??? any good-LUCK & i'll let u know wot happens...
  1. Fried ECM?
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2009, 06:03 PM
  2. Cadence amp fried
    By And_ROOS in forum Car Audio
    Last Post: 08-04-2009, 09:30 PM
  3. Fried Kenwood KDC-2008
    By azzfox in forum Car Audio
    Last Post: 23-05-2006, 07:57 PM
  4. FRIED VR LEVEL 3 Cluster
    By StealthX in forum Electrical Wiring / Questions
    Last Post: 21-08-2005, 08:04 PM
  5. fried my rings
    By griffindore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2005, 09:17 PM
