Hi there
I have a Vs Wagon 97
To cut a long story short the car keeps clicking when you want to start it had the mechanic around monday he replaced the starter motor and now Wed it seems to be clicking again please tell me its not the starter motor again??
his trying to say it could be a terminal??
please help what is it ??
Thanks
sounds like the battery is screwed.
try whacking on some jumper cables and try starting it.. should kick over fine.
also check the cable going from the battery to the starter motor they corrode and there resistance goes through the roof
Float like an elephant sting like a tree clubsport hits what doug does'nt see
VS's are known for alternator/battery/starter motor issues mate, I had a similar issue with my VS not holding enough charge to spark a match. On the back of the alternator there is the wire that leads to your battery (The positive cgarge one). Check that, as they corrode and fall apart at the back of the alternator.
Hope that helps
Ummm My mate said something bout a starting solenoid????
Dunno if this will help just thought I might mention it.
thanks guys
gone to auto electrics to see wtf its doing!!
vs seem to have mind of there own
