Results 1 to 7 of 7
Thread: VS Cooling
    VU S and VS Equipe
    Jul 2009
    Default VS Cooling
    when idling in my vs the temp gauge starts to rise quite a lot but as soon as i begin driving again it cools down once more, does anyone know why this happens and how to fix it? thanks
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    define 'quite a lot', its normal for the gauge to reach 1/2
    heres a thread that was just posted on the same topic Ecotec
    bfc
    bfc is offline
    Oct 2004
    swap the sender unit over for fanif its black put a white one in that will turn fan on at lower temps
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    It's fine. Nothing wrong with the temperature gague reaching 1/2 way. Once it gets around that mark the thermo fan will kick in and cool the engine. Whilst driving not idling the car is sucking in more air flowing through the front of the car, hence keeping the car cooler.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    Why worry if it's not over-heating. Don't modify anything - go and buy yourself a service manual and refer to that for normal operating procedures. I've noticed some people here do a lot of guessing. NOT EVERYONE - it's mostly full of helpful information.
    FYI - running an engine 'cold' will do more damage than normal operating temp's. Unless your fan is not working, leave the f**king thing alone!.
    Have a good day
    VS exec
    Jun 2009
    bong from the gong
    Quote Originally Posted by Jordan88 View Post
    Air flowing thru the radiator cools the water down its the way they work. By driving it you are getting air flowing thru it. The thermo fan comes on when you get to hot to pull air thru the radiator. the fan is only going to do its job in a low speed situation
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Anything up to 2/3 is normal on the gauge for the ecotec, the gauge is very indicative of whats going on. Normal running temps would be around 1/3 or 1/4 depending on the ambient temps, obviously on a very hot day in peak hour traffic the temperature is going to sit closer to just under half. As long as the cooling fan kicks in around the half way mark or just above, you've got nothing to worry about. From memory the low speed fan kicks in around 104 deg C and high speed around 110 deg C. Incidentally the fan actually turns off regardless of the temperature at around 60 km/h as the air flow at that speed is sufficient to cool the radiator.
  1. vn s1 to s2 cooling conversion
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2009, 01:17 AM
  2. Oil Cooling?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-12-2006, 01:31 AM
  3. VS air con not cooling.
    By shmity in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2005, 07:46 AM
  4. Amp Cooling
    By VY2ENJOY in forum Car Audio
    Last Post: 22-10-2005, 12:54 AM
  5. vn s1 cooling
    By fatvgute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 11:24 PM
