Results 1 to 4 of 4
Thread: Vs problem again!!!!!!
    Commodore vs Wagon
    Jul 2009
    Default Vs problem again!!!!!!
    Hey guys
    i put a post on here yesterday about how my car wouldnt start after replacing the starter motor!!!
    Well it turns out that all is good but they are saying that they key could be on the way out and to replace the key and the whole head of it its like 400-500 BUCKS!!!
    has anyone herd of this???
    it must be cheaper then that????
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    no way i think for the keyhead from Holden i think they are about $80 - $100. Best to check with them.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    them saying that the 'key could be one the way out' is not definitive enough. if this is the case it will have logged an error code. check them with a paper clip, the how-to is a sticky in the how-to section. other thing to check is the metal ring around the ignition barrel makes perfect contact with the metal tab on the keyhead. if not gently bend the metal strip out a little bit so it will contact better.
    u can get a keyhead off ebay for say $50 take it to holden and they will program it to ur car for round .5 hour charge, bout $50-100 pending on who u get.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Check out the Mr Minut places in your local shopping centre. You should be able to get a new key and key head for $60 or so that will work with your car.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. A/C Problem
    By IGNITIONSV6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2008, 12:50 PM
  3. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. serious problem
    By fastvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2005, 11:18 PM
