Results 1 to 5 of 5
Thread: Temp gauge not working after belt replacement.
    vs
    Jul 2009
    Default Temp gauge not working after belt replacement.
    Hello everyone and thanks for the info already posted on this foum, its helped me alot.
    Anyway the serpenine belt shredded the other day, very close to home so no probs, got that replaced and it also took out the top radiator hose so replaced that too. All was good ut the engine check light stayed on. Did the diagnostic test using the info from this forum and came up with error 12 and 15..........cut a long story short the belt had knocked the wiring off so fixed that and now the check light doesnt stay on.
    Only problem is the temp gauge now doesn't register at all and having had overheating problems in the past I a scared to drive it as I rely heavily on the gauge to let me know what the engine is doing.
    Having spent a bit already on parts Im not too keen to take it to an auto spaky just yet. Have read on these forums that i could be the sensor or sender but im not too sure which is which.
    Anyone got any clues....TIA
    Karl
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    may sound stupid...but have you smacked the dash with your hand? they tend to stick a little sometimes
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Either that, or do the VS V6's have a seperate coolant sensor for the temp gauge? Or is that just for the 5 litres?
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    vs
    Jul 2009
    Thanks for your help guys.
    Found the problem it was a connector that slides onto the small brass nipple under the thermostat.
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by FiveDockFlyer View Post
    Yep thats the one, a rectangular shaped black plastic connector from memory. Thats the sender unit for the gauge.
    The thicker brass cylindrical one with wiring going to it below the sender is the actual coolant sensor, and the ECU uses this one for coolant temperature readings.
  1. temp gauge not working
    By brod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2009, 08:35 PM
  2. Temp gauge not working ??
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 08:43 PM
  3. Temp Gauge NOT Working
    By VSStatesman in forum Electrical Wiring / Questions
    Last Post: 24-11-2006, 06:12 PM
  4. VS Statesman Temp Gauge NOT Working
    By VSStatesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2006, 05:57 PM
  5. Fuel and temp gauge stopped working
    By tryan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2004, 02:55 PM
