Results 1 to 15 of 15
Thread: Oil light
    VR Statesman
    Apr 2009
    Angry Oil light
    Ok I got another one for you guys.
    I have a VR statesman V8. I just had the oil pump replaced and about 3 weeks later the oil light is on. It has new oil and filter.
    I rang the bloke who fitted the oil pump, and he said undo the bolt on the side of the oil pump, take out the spring and the other thing and stick a screwdriver with a rag up the hole to give a clean.
    did all that but the light still remains. The engine sounds good on start up maybe a little tapitey but sounds good for the amount of K'S 250XXX.
    What do you guys recon I might be?
    VS Berlina 3.8
    Dec 2008
    VR Statesman
    Apr 2009
    last time I checked which was 8 hours before the light come on I got 12-OK, 31 Theft deterrent signal missing key buggerd?, 44 O2 lean, 45 O2 rich (its on gas) and 46 No Reference signal while cranking????
    VR Statesman
    Apr 2009
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    you're lucky you can even start it when you get error 31, I couldnt even get it to crank over when this one started playing up.
    I thought the 5.0L only had one oxy sensor, so how can it be rich and lean at the same time?
    no idea mate, may be a faulty ecu, but dont take that as gospel
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by kummo View Post
    Could be a faulty switch, fairly common problem for both the V6 and V8 engines. When you had the oil pump replaced, I'm assuming that the mechanic also cleaned or replaced the pickup as well? They have a tendency to get blocked fairly easily, especially if oil changes have been skipped in the past.
    VR Statesman
    Apr 2009
    Quote Originally Posted by Harvs82 View Post
    I'll give him a call to ask. thanks for that. I just don't want to drive it back to mechanic and run the risk of stuffing motor.
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    Cool Holden VS Radiator
    Do Holden Vs stock radiators have a bleeder at the bottom, or got ttake off bottom hose
    Tit-Tit-Titian™
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check if you actually have oil pressure by removing a rocker cover - check that oil is coming from the rockers indicating oil is being pumped thru the system. If it"s not being oiled I wouldn't drive the car. The thing the mechanic asked you to remove and clean is the oil pressure relief valve - possibly he figured that some dirt had blocked the valve making it stay open all the time - this dumps the oil back to the sump instead of into the oilways. Good Luck.
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by lyndon_breeze View Post
    Think you might have posted this in the wrong thread mate, but no, if you need to drain the radiator you need to remove the bottom hose, and this will still leave plenty of coolant in the block too. There is a bleed point on the top of the thermostat outlet at the top of the engine though.
    VR Statesman
    Apr 2009
    Quote Originally Posted by hako View Post
    Sounds like a bit of a mission taking a rocker cover off. lol. Is their a way to look at oil pressure through the trip computer like you can check other stuff by pressing the arrow keys???
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Have yoou checked the oil level?
    when is hot?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    if you dont want to rmove a rocker cover you could try looking through the oil filler hole to see if you have oil flowing up there..
    VRCITY's Avatar
    VRCITY is offline Cruizin' is gud 4 da soul
    VR Executive
    Jul 2009
    Melbourne, Eastside
    Rito, well if possible find a mech with a fairly good scanner which can read oil pressure switch operation, if not just replace it...they fairly cheap. and checking oil level won't hurt...and "greenacc" made a good suggestion jus remove oil filler cap to see if you got oil circulating. My other note refers to the rich/lean codes present in ECU...even on gas the sensor should still operate normally which is once warm operate in lambda...if the sensor stays either rich or lean for longer than something like 15 secs or so it will register a code. This said i would be getting a good gas tune and if this is still registering replace the sensor...also could have a bad earth on it. lol so many things and i'm going of topic...lmao sorry champ um...yeh couple of things to try...hit me bak any q's
    VRCITY
  15. #15
    E46 M3
    Jun 2009
    its definitely your oil filter, upgrade it to a k&n and it'll solve your problem
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  3. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  4. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
