Results 1 to 10 of 10
Thread: battery light?
    vs ute s 5.0L
    May 2009
    Default battery light?
    hey guys got an annoying problem everytime im driving the battery light is bound to come on why is this?
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    vs ute s 5.0L
    May 2009
    vr berlina
    Aug 2008
    could also be the alternator regulator, i had this same problem and after checking everything it turned out to be the regulator
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    There will be an issue with the charging system, as others have suggested the regulator could be stuffed, or the brushes could also be worn. I'm not sure if the same problem happens on the V8 engine, but on the V6 the main B+ wire and connection burns out at the back of the alternator, which could cause some issues.
    Also check that all the connections to the battery are clean and secure, and also check that the wiring and connections at the alternator is also secure. You can also check the voltage with a multimeter to see what the charging rate is like, it should be around 14 volts at idle with no accessories ie lights or air conditioning running.
    VS Berlina S1 V6
    Jul 2009
    Yea, as Harvs82 said, that wire at the back of the alternator is prone to problems. Happened with mine mate, got a battery light first, then got it checked and told there was no problem. Two weeks later and bang, no charge wat so ever, 11 at night, no electronics, lights, box, etc. That sukd.
    Obviously with yours' being a 5L, could be different, but it's still worth a look mate.
    The1's Avatar
    The1 is online now A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    check the fat wire at the back of alternator, they have a habit of braking off. You'l have to take the engine cover off.
    vs ute s 5.0L
    May 2009
    Vs Executive
    Jul 2009
    hay ive just had a battery die on me. put a new one in. and straight off my batterey light's come on. but i had a new alternator put in like 6 months ago..is it still likely to be whats causing me grief?
    MX83
    Jul 2008
    hills area, sydney
    Check to make sure the terminals are clean and secured properly. Also, do you have a multimeter? You can check the voltages at the battery and alternator aswell to see where the problem is.
    JCCC NSW
    Quote Originally Posted by Troy711 View Post
    My mum dropped me off at work one day and she was doing 90 in a 60 zone. When I pointed this out to her she said 'shut up, if you don't like my driving you can get out and walk'.
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  3. battery light on & orange light on
    By smokey.29 in forum Electrical Wiring / Questions
    Last Post: 12-02-2007, 06:16 PM
  4. VP Battery Light
    By lostsoul1972 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2005, 09:24 PM
  5. battery light
    By CSD in forum Electrical Wiring / Questions
    Last Post: 02-06-2004, 08:10 AM
