Results 1 to 6 of 6
Thread: vr engine squeek
    vr berlina
    Aug 2008
    Default vr engine squeek
    just yesterday i noticed that my car was squeeking from the front right of the engine bay, im guessing that its a belt that needs to be replaced, but not sure, wondering if anyone has had this same problem and what it is and how much it would be to fix and how soon it needs to be done?
    also i hve noticed sometimes when im in the hills driving in third if im just cruising and then go to accelerate takes a second to kick into gear...does this mean my trans is on the way out?
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Yeah changing the belt would be the first thing I would try - I had a similar problem, that got worse as the engine got warmer. Replacing the belt fixed it.
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    or just try soap on the belt. only change belt if got cracks in it
    Tit-Tit-Titian™
    VRCITY's Avatar
    VRCITY is offline Cruizin' is gud 4 da soul
    VR Executive
    Jul 2009
    Melbourne, Eastside
    soap or a stick or drill lube if its jus noisy and trans aint my thing...possibly on waay out..is auto or manual??
    VRCITY
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It probably is not the belt - usual cause is a bad pulley bearing gone dry and squealing. Remove the belt and spin each pulley by hand to find the dry bearing. New pulleys with bearings are about $30 ea.
    I'd fix this soon as if the bearing fails completely it will throw the belt and you will be stranded on the side of the road.
    E46 M3
    Jun 2009
    ^^^ what he said
  1. Squeek
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2009, 05:17 PM
  2. Squeek in the rear right wheel
    By [Linkin Park] in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-11-2008, 08:01 PM
  3. steering wheel squeek
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-03-2007, 07:56 AM
  4. Aircon Squeek
    By MartinV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2006, 08:07 PM
  5. squeek over bumps (suspension)
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-12-2005, 10:39 AM
