Results 1 to 8 of 8
Thread: oil light
    vz ss and vs statesman
    Mar 2009
    Default oil light
    hey does any 1 know or have any ideas why my oil light keeps coming on. Oil level is fine only just happened tonight after a bit of a thrash. Is it my oil pump or oil switch. It is a 5l statesman wit 270000k on the clock
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    if your oil switch is leaking oil on the plug thats a good sign, could also be main or conrod bearings is your motor sounding noiser?
    Mar 2009
    no its not noisier started it this morning and there was no noise at all and no oil light ran perfect so i dont know
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Could be a faulty switch... or it could actually be poor oil pressure, especially as the oil would have thinned out a bit with a good thrashing. A common problem is that the oil pickup gets blocked, particularly on the 5 litre engine, especially if oil changes have been skipped in the past, the pickup can get blocked with sludge etc. With 270,000 on the clock things are inevitably going to be wearing out, but i'd start with flushing the engine oil with engine oil cleaner, dumping the oil and oil filter and replace with a new filter and oil and see how you go then.
    VX L67, ln106 hilux, xr600r
    Jun 2009
    qld
    thatd be your oil pressure switch,id put my left testicle on it! hmm well maybe? well thats what it was on my V6, $22 it was
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    done 270 xxx maybe its needing a rebuild get it checked out
    {H1GHROLLR} CHEMICALLY SUPERCHARGED A.K.A NITROUS FED R8 CLUBBY and {HYPED UP} TWIN TURBO VX SS DAILY
    vt s s1
    Mar 2009
    I know the ecotecs are known for there oil pickup issues with getting blocked and what not.
    Recomended to change oil and filter every 5000ks or so instead of 10
    VS v8 manual Calais, Ve ute, 68 Hk Holden v8
    Aug 2009
    coalville, vic
    hey, my vs 5ltr has bout 230,000 and after drivin up into the mountain ranges, the oil light was just flickering while in drive and idling, its the oil just gets hot and loses its viscosity, so less oil pressure. oh and oil changes at evey 5000 are the go!!
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  3. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  4. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
