Results 1 to 6 of 6
Thread: O2 Sensor Problem - Pacemakers
    VS Calais S1
    Jul 2006
    Kadina, SA
    Question O2 Sensor Problem - Pacemakers
    Hey guys,
    Last weekend I put a set of pacemakers on my VS Calais. Now all is good and well however tonight i noticed my car was blowing tons of white smoke
    So anyway I held down the mode and set buttons and started it up. Now I am not sure what it means but on the "FUEL 1" screen it was reading about 2 while on the "FUEL 2" screen it was reading close to 6.
    Is this the a problem with the O2 sensors? The sensor on the left hand side wouldn't reach the plug once in the pacemakers so I cut the wires and soldered some more in so it would reach. Was I wrong in doing this and could this be causing the problem? If so how do I go about fixing the issue?
    Cheers.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    as long as you used thick enough wire and got the right connections to each one it should be fine nice shiney solder joins i presume taped up well you should be laughing.fuel smoke is normally black white is normally oil
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by RoboticCherry-Coke View Post
    Fuel 1: Fuel consumption in L/hour: I think 2 L/hour is reasonable at idle
    Fuel 2: Fuel tank sender: 6 V means just over half full
    see thread: VS Tips and Tricks - You May Not Know About
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Blowing white smoke isnt good, if it was running rich it would be black, but white? burning oil or blown gasket.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    New headers will burn residual oil from the tail pipe and also burn off the greasy finger prints on the headers themselves.
    VS Calais S1
    Jul 2006
    Kadina, SA
    Thumbs up Paranoid..
    Thanks alot for all the replies and help guys. Just went out and started it up again to see how things are going and no more smoke... So who knows I guess I am just paranoid but REV is probably right, I did drive for a fair bit last night so it was probably just burning off residual oil and what not. However I will keep an eye on it none the less just in case. Again thanks alot guys.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. Can`t find O2 sensor on 5.0ltr pacemakers
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2008, 08:59 PM
  3. Map sensor problem
    By adam69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2007, 05:53 PM
  4. Oxy Sensor Problem
    By some_evil in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2006, 12:23 PM
  5. VR Oxy Sensor Problem
    Last Post: 23-03-2005, 08:03 PM
