Results 1 to 3 of 3
Thread: steering
    94 vr HSV gts 6speed 5.7stroker 215kw
    Jun 2009
    no where
    Angry steering
    hi there,i need to take a pully wheel of a power steering pump shaft the manual says to use a three armed pulley remover i when and hire one today cant seem to get pulley wheel off the shaft all the puller is doing is bending in the outer side of the pulley,what i need to no if this the correct way or removing the pulley from the sharft or is there another way, if any body has a sollution to my problem.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    If that doesn't work maybe try sitting the pulley on the two blocks of wood and hitting the shaft with a big punch in the centre. The V6 pump pulley is bolted on, but i'm assuming the V8 is different ?
    Jun 2009
    no where
    Unhappy
    yeh the pulley system is different the shaft has a drilled hole with a thread put into the sharft it might be pressed on i think there must be some sort of puller out there?
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
  3. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  4. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  5. Speed sensitive steering to exec steering??
    By pest in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2004, 08:50 PM
