91 or 95 im thinking , car has extractors and exhaust if that means anything.
for the extra few cents i throw 95 in.
Forecast For Tonight Is Alcohol, Low Standards And Poor Decisions.
Unless it's tuned for higher octane there'll be no performance gain in using it. Most premium fuels have extra detergents added to them to keep the fuel system clean, so the occasional tank may have it's benefits.
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
notice any difference? economy or tromping wise?
unless ur car is running higher compression i dont see the point
Premium keeps your car cleaner even though you make other reasons up for being a cheapskate
Also it does run smoother, and no, this isnt placebo effect. Call it personal opinion, but I can justify 6 dollars a tank more to keep my baby happier.
I run 91, but every now and then i put 98 in it for a long trip to give her a bit of a flush through. I think it actually uses more fuel on 98.
after testing with various cars, including a stocko vx HBD with an ecotec, yes it ran a alot smoother on premium but consumption wise was only about 50ks different..
98 is really a waste of time, if your not tuned to it your engine cant make full use of the burn which is actually slower than a fuel with lower octane
do you mean tuned ecu or extractors/exhaust/cai
Yeah the ecu...
The stock computer cant advance the timing enough to make use of the better burn
tuned ecu incoming in the next couple of weeks anyway.
what sort of fuel is it tuned to?
its from delcowizard, he says it will benefit from 95 octaine but will run fine on 91.
then run 95 with the new ecu
try a bit of 91 when its nearly empty and see if you notice any difference
good luck mate
will do, thanks.
