Hey Guyys
How much does it cost to get front rotors and new brakes put in a vs wagon>??
Mine have gone steering wheel shakes when i brake
iv been quoted 500-600 $$$ ?????? is that a ripoff
Thanks guys![]()
why dont you get them machined?
pads are only like $60 for good qaulity ones
well i was going to but mechanic reckons its not worth it
front standard rotors are around $80 for the pair, and pads are roughly $30 and all you need is a jack, stands and a couple tools and away you go. you can use the guide thats in the how-to section. is on VT-VX brakes so the calipers look a little different, its the same process.
in other words it is a big rip off.......and if you do it yourself you'll save $$$
the rotors are floating, so its only 2 caliper bolts and bam rotors pretty much fall off, if they are stuck on just bash behind them with a mallet, failing that then hammer but it will ding them but they are going in the bin so dont worry. Slap new ones on and do up 2 bolts.
Do not pay more than $200 for new rotors and good pads, you would be being ripped at the $200 mark.
Yer i got 2 front DBA slotted rotors for 100 bucks and bendix premium pads or something long that line.
500-600 is a rip, especially caus you have no idea about the quality of parts being fitted.
DBA (quality brand) rotors are about 50-60 each, slotted being about 110 each.
Bendix General CT pads are 50-60 bux.
So thats 150-180ish bux in parts.
To do it yourself you need:
A Jack and wheel brace.
19 or 22mm spanner to remove the caliper.
a 10 and 12 mm (or 12 and 13) to remove guide pin bolt.
A G-clamp to push caliper piston back in.
A couple of hours and a few beers.
I've done it for under $200 and within an hour, easy and cheap.
And slide hammers FTW!!
Unless your getting cross drilled and sloted rotors with performance pads then yeah, your getting ripped off.
I can do you a set of slotted rotors and pads for $195. Where abouts are you?
