Results 1 to 8 of 8
Thread: vr dimmer headlight switch
    '94 VR Commodore Executive
    May 2006
    Default vr dimmer headlight switch
    hi guys!
    recently l acquired some items from a vr berlina to go into my vr executive to which was including the headlight switch. I put it in and now my dash is really dim. Was wondering if there was a difference in the base model with the headlight switch?
    I have the switch set in the middle. I can go down on the switch and it doesn't do anything but spring back up. If l go up it can lock into place making my dash brighter but my interior light also stays on. Any ideas?
    Thanks
    See My Ride: VR
    VR II Executive Manual
    Apr 2009
    Sounds like it's broken - my VR Series II Exec has a 3 position switch like you describe, but it works as
    1. Bright dash + interior light
    2. Bright dash
    3. Dim Dash (never did work out what that was supposed to be useful for)
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Quote Originally Posted by theSeekerr View Post
    2. Bright dash
    bwahahahaha, that is so true
    Reaper
    E46 M3
    Jun 2009
    your switch is cactus...
    swap for your old one or buy a newy from holden ~$30-$40
    May 2006
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    The berlina/calais didn't just have 3 stages of cluster dimming. You hold the switch up/down until it adjusts to the level you want, then let it go and it goes back to the middle. If you push it all the way to the top then the interior light turns on.
    This is in a VS, and as far as I know VRs were the same
    Apr 2009
    May 2006
    hmmm... so the switch is fine but l can't use it as it makes my dash practically unreadable.
    See My Ride: VR
  1. SV6 Headlight Switch
    By Pittster83 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-05-2009, 06:06 PM
  2. [VIC] WTB need vp calais/ vq statesman headlight-dimmer switch
    By hi_ryder in forum Swap / Wanted to Buy / Trade
    Last Post: 02-12-2008, 07:40 PM
  3. Replies: 5
    Last Post: 14-06-2008, 03:41 PM
  4. vk headlight switch
    By holdenmum in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-01-2008, 01:24 PM
  5. vt headlight switch
    By scotto1825 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2007, 11:52 PM
