Results 1 to 6 of 6
Thread: Vr Ute - not running right
    Vr Commodore Ute
    Jul 2009
    Default Vr Ute - not running right
    Hi Guys,
    Im linzi i have just purchased a vr ute, and its not running right,
    It is very sluggish off the start, and sometimes konks out for no reason, (while driving and somtimes stopeed), the idle is rough sounding and always sounds like it wants to cut out on me, does anyone know what this problem might be as im a chick and have no idea what this could be??
    Any help would be great
    Thanks
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    next time u buy a car get sumone that knows a lil bit about cars to go with you, could be flowed plugs, shot leads, ignition pack or a simple idle control valve
    Vr Commodore Ute
    Jul 2009
    Yea when i brought the car it seemed to be running fine, its just recently its started to konk out and idle really rough, thanks for the reply.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    First thing to do is a codes check - instructions are here and it is very easy to do and may give you a clue - tell us the results: Checking error codes VR/VS (Revised)
    I've got 4 daughters who all know basic car maintenance and look after their cars better than my sons ....you can do the same.
    It sounds like a bad plug or a lead but do the codes check first....and ask questions.
    Good Luck.
    Vr Commodore Ute
    Jul 2009
    Hi ,
    Thankyou very much for this, ill def have alook at those codes over the weekend.
    Yea my plan is to look after my baby as much as i possibly can .
    Thanks again
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    My VR was doing the same thing and it turned out to be a gunky Throttlebody and Idle Air Control Valve. Some carby cleaner and a rag fixed that up
  1. its running, what should i do now??
    By orreal511 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2008, 11:01 AM
  2. VR VR Running Hot
    By Brutus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2006, 08:07 PM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. Vn V6 Running
    By cohn in forum Parts And Other Items For Sale
    Last Post: 18-07-2006, 09:52 PM
  5. VN not running on all 6
    By brotton1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2006, 11:49 AM
