Results 1 to 5 of 5
Thread: Power steering noise..
    vl calais turbo, vs exec
    Jul 2009
    Default Power steering noise..
    Hey guys,
    Not so much of a serious issue im just hoping somebody can tell me what im hearng.
    Car makes a dripping/ girgling water/ fluid noise when turning, happens mostly when going through a round about (turning left then right)
    My girlfriends barina does the exact same thing.
    Anybody know what it is?
    Cheers!
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    air bubbles in power steering rack?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Jul 2009
    Thats the problem or is that a guess? sounds about right, ways to rid it?
    Commodore vs Wagon
    Jul 2009
    Im sure my vs does this when i steer left or right i thought it was normal!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It could also be air trapped in the heater matrix (remove by bleeding cooling system) or water trapped in the airconditioner due to blocked drain. If the power steering fluid reservoir is very low then it may be the power steering. There is also a grommet which the steering column passes thru (on the firewall) which is made of plastic - it gets dry and makes a rubbing/squeaky sound. Fix with WD40.
  1. Power Steering Noise
    By Huthy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-06-2010, 06:31 PM
  2. power steering noise on vs
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2008, 09:13 AM
  3. power steering noise?
    By burnsy150 in forum General
    Last Post: 29-01-2008, 11:21 AM
  4. power steering noise???
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2005, 06:36 PM
  5. Power Steering Noise
    By vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2005, 07:57 PM
