Results 1 to 7 of 7
Thread: 5,0L Pacemaker
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default 5,0L Pacemaker
    quick question.
    a mate of mine is wrecking a vs ss 5.0litre and it has pacemaker extractors on it. will theese fit my 5.0litre vr caprice? cheers
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    looking on the website ill need the PH 5000V
    and the ss ones will be PH 5000D.
    afaik its the variable ratio steering. is it really that limiting or can i get away with putting normal ones on? anyone with some knowledge please let me know.
    Jun 2005
    no they wont fit on
    5000V will fit on a normal commodore (i have these on mine) or a stato/calais with the variable speed rack
    5000D will only fit on a normal commodore
    if you were in vic i would probably trade the drivers side header with you
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Its really tight down the drivers side there. I have not seen the variable rack but the extractors are most definatly a bit of a tight custom bend to get through that area between the rack, bellhousing and floor pan there. I would imagine there is 2 different part numbers for a reason as i would imagine the rack is bigger and a different shape to bend around. Im not sure though how hard it would be modify them if you know a mate whose a fabricator or somthing. The passenger side will fit though.
    Reaper
    Jun 2005
    yeah the drivers side do have a few odd bends in them. i wouldnt bother attempting to fit normal commodore ones in. theyre annoying enough to install, and it would just be wasted time with the wrong header
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    5000D are the dual cat set up. They don't come with a Y pipe.
    Yes, the V's are backwards compatible, but you can't go the other way.
    Visit my Facebook page
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    ahh cheers for that guys.
    abba fan when i get my tax back i think ill be coming to you for the pacemakers.
  1. HM or pacemaker
    By ryan_VX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2009, 07:16 PM
  2. pacemaker extractors for $250
    By bigneilsen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2008, 03:17 PM
  3. Pacemaker?
    By tuffvn6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2008, 11:00 PM
  4. pacemaker
    By nathans1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2007, 05:01 PM
  5. Pacemaker
    By bush_basha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2006, 07:33 PM
