Results 1 to 8 of 8
Thread: Vs acclaim
    vs commodore acclaim series 2
    Dec 2007
    Default Vs acclaim
    Hi i recently have noticed a problem when drivin. At times, mostly when my headlights and radio are on at night, my battery light comes on, then my abs light, then my airbag light. Ontop of that my headlights and dashlights seem to become MUCH brighter. My amp also cuts off. This lasts for about a minute, then everything goes back to normal. I HAVE changed my spark plug leads recently but i dont know if that would be the problem. The battery also shows that its fully charged. ANy suggestions....
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    check your engine is properly earthed
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Dec 2007
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    checking the condition of the earth cables, there should be about three thick braided flat wires running from somewhere on the block to the body of the car. If any of them are cut or missing that could be your problem. Not sure where all of them are on the V6, but one should be near the alternator.
    The hall of fame:
    ಠ_ಠ
    Dec 2007
    ive checked and they seem fine. Also checked my amp wire that runs to the battery and that looks fine also. Checked my leads, they are properly fitted. Battery also still says its fully charged. Not sure what else it could be?
    Dec 2007
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Id be checkin ur voltage when it does it, as ur headlights get brighter id say ur regualtor is playin up n voltage is increasing.
    Amp will turn off at anythink over 15v im pretty sure.
    Deff get a multi meter on it tho with car off, check voltage, start car, check voltage.
    Should sit between 11.9v-12.4v car off and 13.9v- 14.4v car on, any higher than that new regulator.
    ________________________________________
    RufusŪ's Avatar
    RufusŪ is offline I Jizzed in my pants
    VR S1 S Pack, VX S2 Acclaim Wagoon
    Apr 2005
    The Marsh, Vic
    Definitely sounds like the regulator on the alternator. If you can't test it, rip it out and take it an auto elec. If it is, will probably cost about $60 to replace and takes about 2 mins to do.
    Signage, Splash Backs and Display Systems
    "No, I'm not a pessimist. At some point the world shits on everybody. Pretending it ain't shit makes you an idiot, not an optimist."
  1. My New VS Acclaim ;)
    By Toddlez in forum VR - VS
    Last Post: 07-05-2009, 11:52 PM
  2. [QLD] F/s 95 vr acclaim s2
    By Chilli_Red in forum Vehicles For Sale
    Last Post: 25-04-2009, 10:01 PM
  3. 94 VR Acclaim
    By mammalian in forum VR - VS
    Last Post: 11-03-2009, 07:02 PM
  4. VT Acclaim $$$???
    By cdawg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2006, 07:03 AM
  5. F/S [per]96 VS Acclaim S2
    By PerceptionTwin in forum Parts And Other Items For Sale
    Last Post: 24-07-2006, 10:23 PM
Tags for this Thread
