Results 1 to 6 of 6
Thread: thermo fan question
    Jan 2008
    Default thermo fan question
    Hi guys/girls
    Bit of background first..
    When i bought my VR, all the air conditioning lines had been cut out, and i later found out the engine was rooted. Great deal right? lol
    Anyway i bought a vr wreck and swapped motor, gearbox and all the aircon components into mine.
    Now that i have a condenser fan to deal with, i had a look in the wiring diagram, im not much of a sparky but it seems to me that it doesnt matter which plug the thermo fan or the condenser fan plugs into, because they both seem to go back to the same place. (Please correct me if i'm wrong)
    Anyway when ever i turn the ignition on one of the fans turns on immediately, depending on which plug its plugged into.
    I was under the impression the thermo fan doesnt kick in untill its hot, and the air con fan wouldnt kick in unless the air con was on.
    Anyone got any ideas?
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by Bitemylip View Post
    Hi guys/girls
    Thermo fan shouldn't come on unless the coolant temperature sensor has told the ECU to turn it on, and the condensor fan should only come on when the A/C is turned on, or the compressor clutch is engaged. The thermo fan might come on as well, to help keep the coolant temperature regulated with the extra load on the engine.
    I think there is a fail safe with the coolant sensor, in that if it is buggered completely, it continually runs the thermo fan as a precaution to prevent overheating.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You are correct - they both are on at the same time according to the wiring diagram:http://www.memcals.com/pdf/VRV6%20Ma...%20Diagram.pdf
    In your case, I'd wire a switch into the fan circuit to manually turn the fans on.....may save a lot of wiring hassles.
    Jan 2008
    Thanks for your responses, I'm going to give my coolant temp sensor a look at tomorrow, as it also has a hard time starting when cold, no temp signal from sensor = wrong fuel ratio i am guessing??
    If no go, i switch sounds like the way to go.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    could also be the ecu having a sad, mates vs ute was cooking itself
    changed the ecu and she is running normal
    Jan 2008
    Think ive fixed the prob, checked the sensor, and it was within spec.
    Had a good look at wiring, and saw wiring had been hacked into, and modified to run straight though the fan relay, so to keep it running all the time. I think they did this due to the temp gauge not working before i did the engine swap. People do some crazy things.
    Soldered original wires back together, and no more fan when cold. Still gotta wait to see if it operates at the right temp though.
  1. Fitting new air filter and thermo question.
    By Flange in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-06-2009, 01:34 PM
  2. Thermo fans question
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-02-2009, 08:58 AM
  3. Thermo Fan Question
    By Flat_White in forum General
    Last Post: 12-07-2008, 08:45 AM
  4. VX II Thermo fans Question Do both go at once??
    By Decksta in forum Electrical Wiring / Questions
    Last Post: 04-09-2005, 07:37 PM
  5. VX II Thermo fans Question Do both go at once??
    By Decksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2005, 10:02 PM
