Results 1 to 11 of 11
Thread: Debadging problem
    VS Equipe
    May 2009
    Default Debadging problem
    hello all,
    i debadgd the equipe logo's on my VS and they came off prtty easy. but the glue that was there is rock solid and i dont think i will be able to take it off withouth removing paint
    any ideas?
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by Crossy_014 View Post
    any ideas?
    Put the badges back on
    There was a debadgeing thread here somewhere and if I remeber correctly, the OP used some solvent to soften and remove the glue.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    VS Equipe
    May 2009
    Quote Originally Posted by woteva View Post
    will solvent damage my paint at all? or dull it?
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    nope it shouldnt...go to an auto shop and ask for "prepsol" or a similiar glue/wax remover worked fine for me
    E46 M3
    Jun 2009
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    carmel wheel will take it off. set the drill to a slow speed and take ur time.
    VL
    May 2009
    prepsol works perfect, then a good polish or overall cut and polish depending how fussy
    - --FS - SI VL Calais Turbo (no Motor) Good Project -- -
    Vy Sv8
    Jun 2009
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Apperently caramel wheels will burn your paint if you have acrylic paint. I haven't taken the silicon off my doors because I never got a definite answer if I have 2pac or acrylic.
    For my badges, I used wax and grease remover that I got from Autobarn.
    HoldiX's Avatar
    HoldiX is offline Holdens Wer the Heart Is
    1988 Nissan Skyline Silhouette
    Feb 2009
    Vic,narre warren north
    The best way badges door strips or stickers is a heat gun it melts the glue easy and things just peel off
    VS Commodore series II
    Mar 2009
    Port Macquarie
    wax and grease remover, it will ball up into a heaps sticky glob, just keep rubbing your thumb over it, youll get it, caramel wheels are okay just go over it lightly and dont stick in 1 spot for too long, it wont burn your paint as soon as you touch is, if you do use a caramel wheel and burn it, put it back on to cover, or get it touched up, even if it means 10 sec to cut at it with the caramel wheel and a 1 minute cooldown for the wheel, just take it slow to be sure
  1. DeBadging Stato Taillight
    By EVIL-LS8 in forum General
    Last Post: 01-05-2009, 10:51 PM
  2. Debadging help
    By Brin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2009, 12:46 PM
  3. Debadging VN Wagon
    By Kuka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2008, 10:34 PM
  4. debadging problem
    By whitevrboi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2008, 08:34 PM
  5. Debadging
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2007, 06:11 PM
