Results 1 to 20 of 20
Thread: Keyless Entry
    VS
    Jul 2008
    Default Keyless Entry
    My remote key has begun to fail when trying to open or lock my central locking.
    I recently replaced the car battery, but, it was happening before this also.
    Is there a battery in the key?
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    VS
    Jul 2008
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    can't help with that. something must unscrew or slide but i don't know what a VS key looks like.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    its not something you can open and then put back together easily.
    foot the bill for two new ones from Mr.Minit for $100
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It can be split with care and then get a battery from Jaycar (has tags attached). Otherwise Mt Minit does the head alone for $80 or the whole key for $100 - sometimes they are on special as well. Usually the press buttons fail first.
    1995VS V8 and 1992VP utes
    Jun 2009
    NZ
    batteries soldered in and I found it hard to desolder and get out,in fact I ended up at Mr Minit for a new one
    Vy Sv8
    Jun 2009
    Quote Originally Posted by Delta02 View Post
    Me To. I tried to change the battery ended up at mr minute getting 2 new keys.
    VS Commodore series II
    Mar 2009
    Port Macquarie
    CU5H1NG is offline CU5H1NG
    VS Acclaim
    Sep 2009
    Merrimac, Gold Coast
    Quote Originally Posted by FullySick View Post
    i am having a weird problem as well with my keyless entry on my VS. i usually carry around my brothers to and from school so i have to unlock all my doors so i use the key in the door to open. i know i should unlock the car with the remote but im lazy ha. but i lately it has started to ONLY lock and unlock all the other doors except mine!!!
    drivers door makes like a buzzing sound as if it is trying to unlock and lock but no go on the . it is the battery in the remote??
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by CU5H1NG View Post
    ... but i lately it has started to ONLY lock and unlock all the other doors except mine!!!
    Probably not no. I would wager money on the central locking actuator being on its last legs.
    VR Executive S2
    Jul 2009
    Victor Harbor SA
    Im getting a new key made for my VR to give my GF (I feel a tremor in the force LOL), my key is a standard single button key, to get a duplicate its gonna cost me $121.
    vk
    Nov 2009
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Its the central locking actuator in your drivers door, its a 5 pin 1 which is much less comon to the 3-pin one found in the rest of your doors, so not just any actuator will work. You need to pull one out of the drivers door of another VR-VZ commodore. I dont know how the VN-VP central locking system works, so I dont know if you coulduse one of those
  15. #15
    vs executive commodore
    Aug 2009
    Quote Originally Posted by vs-ute-119 View Post
    yea the keys are weather sealed. some of the older keys can be pulled apart such as the early VR keys and we also sell cases (im a locksmith) for the three button commodore keys for the VT-VZ so they can come apart with a bit of prising, however i havent done one so i wouldnt know how easy or hard it is.
    batteries generally have a lifetime of about 15 years.. but yea i know the keys do seem expensive but just be glad you dont have to buy a genuine toyota key..
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by amark View Post
    i just wanna no how to start a new thread thanks
    Go to the top of the previous page (VR-VS) and on the left hand side is a blue tab marked "new thread"
    ....click on that and you are away.
  17. #17
    VS Acclaim
    Sep 2009
    Quote Originally Posted by Andrew426 View Post
    ahh sweet thanks so much. so i could just go down to a commdore wreckers and find a VR-VZ door and take it out?? how much do you reckon??
    thanks Andrew426
  18. #18
    Jan 2008
    Not sure, probably not more than $20 or so. Take a set of allen keys with you as well, you will see why.
  19. #19
    VS Acclaim
    Sep 2009
    alright then sweet i thought it wouldve costed like $100 bucks haha and lucky for me my car is still under warrenty
    cheers andrew
  20. #20
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    you actually need a set of torx bits.
  1. Keyless Entry
    By judd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2008, 09:08 PM
  2. keyless entry
    By mason_luke in forum Electrical Wiring / Questions
    Last Post: 05-11-2007, 11:58 AM
  3. Keyless Entry?
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2006, 11:41 PM
  4. Keyless Entry
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2006, 03:01 AM
  5. Keyless Entry
    By blitzpc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2005, 07:36 PM
