Hi, i have been having lots of troubles with my car.I am not sure what is going on as the fault codes say that the system is running fine but the car lacks go.In drive (or any of the forward gears) it feels like the car has three ton in the back end. It will not go above 40km/h but in reverse she is fine.Does this sound like a transmittion problem or a diff problem??
Sounds like it's in limp home mode.
Either that or you need a new transmission.
how can the limp home mode be fixed??
It can't be removed unless you fix the fault - do a fault code check to find the cause and then you will have to rectify the fault. Instructions are at Checking error codes VR/VS (Revised)
It's easy to do and you only need a paperclip. Report back with what you find.
have done the fault codes and it keeps displaying code 12 which according to my manual is saying there is no problem which of course there is
computer will only record a code when the engine light comes on, so if it isnt coming on, checking codes is useless.
Could be any number of things though... Transmission, Fuel supply, ignition system...
Can the car rev freely in park? no odd noises or misfiring?
engine light is coming on but no fault is recording.Fuel system is all fine.Could it be the ECU playing up?
could be the ecu it controls the gears as well as the engine maybe find someone to borrow one off to test for a half hour and see how it goes.
Check colour and smell of transmission fluid - shoud be reddish and not smell burnt.
If the fuel filter has not been changed recently it could be partially blocked.
Has any work been recently done to the car....how is it driven (granny/hoon)?
ok the trans fluid is fine, at correct level and in new looking condition.
fuel filter was changed a few months ago. No work has recently been done except the basics i.e. sparkies ect
I dont drive her like a granny but i dont spin the wheels either.
ECU is now reading code 81 which is said to be - 2-3 Shift Solenoid “B” Fault -
Does this indicate the the trans is stuffed or can it be fixed??
Does anyone know a good repairer in adelaide that could replace the soliond and what cost would i be looking at??
thanks to everyone for their info. Soleniods have now been replaced and she is as good as new
