Results 1 to 2 of 2
Thread: VS ute stalls whilst driving.
    VZ saloon/VS series 3 ute
    Jul 2009
    Default VS ute stalls whilst driving.
    Gday all, problem with a VS series 3 ute. For no reason that can be detected the drive train warning light flashes on very briefly for less than a second followed by engine stall.
    She so far restarts without a problem and all is well. Happened three times in the last month. Local mechanic checked out and cannot find problem, no fault codes in computer.
    Fuel system is fine, clean fuel etc. Ute has 170k on the clock. Fault appears within about 15minutes of starting from cold.
    Anyone else had this problem before?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    May be the CAS which may not always leave a code. If it is the CAS it will get worse.
    If this problem happens when cornering with fuel level below 1/2 it may be fuel related as utes have a problem there.
    Also check the "similar threads" section at the bottom of this page....
  1. Vs Engine Light one and stalls whilst driving..
    By sxy677 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2009, 06:35 PM
  2. Car Shuts Off Whilst Driving.
    By vs_commy5506 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2009, 03:47 PM
  3. VS SS headlights dim whilst driving
    By paulforaname in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2009, 09:52 PM
  4. Ever had any close calls whilst driving?
    By Flat_White in forum The Pub
    Last Post: 22-08-2008, 04:41 AM
  5. VX Commodore stalling whilst driving!!!
    By chipper_222 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2006, 12:47 PM
