Results 1 to 17 of 17
Thread: Crank Angle Sensor Problems
    95' VS V6 Commodore
    May 2005
    Question Crank Angle Sensor Problems
    Hi.. Ive been having problems with my VS (V6).. Its been stalling but only when im slowing down at the lights and just when im changing gears. Its an auto. (Ive had to replace the crank angle sensor a few times over the 6 years ive owned it.) .. Its almost like it doesnt like sitting below 1000rpm. This time i got error 49. Crank/cam signal intermittent. We changed the crank agle sensor again and its still stalling. Does anyone know what this could be? Or why i have to change it so often?
    The same problem all the time is really starting to p*ss me off
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    it might not be your CAS. The CAM signal comes from your Cam angle sensor which you will see on the front of your engine near the water pump. It could also be a dodgy coil playing with your DFI and sending dud codes like your 49. There's a test procedure in gregory's to check the cam sensor. (cam sensors cost more than CAS.
    95' VS V6 Commodore
    May 2005
    Thanks for that. Im not gonna bother with testing it, changing that CAM sensor tomorrow, As long as ive owned it its never been changed. Least if its still happening that will be one thing ruled out
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd go with what greenacc says, plus I'd double check or replace the connectors and wiring to the CAS...maybe you have an intermittent connection there.
    95' VS V6 Commodore
    May 2005
    Ive changed the CAM sensor and all seems to be going ok. Fingers crossed it doesnt stall on me for a while.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Please let us know how it is going after awhile.
    Something for me to keep in mind thanks.
    Could it do the same on an auto???
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    95' VS V6 Commodore
    May 2005
    This is an auto. It shuddered a bit this morning when i started it up, stalled once while still pretty cold, but then all seemed to go ok. Im thinking there is still an underlying problem somewhere, It seems to be running a little rougher than normal.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    glad to hear its getting a bit better. Maybe check and clean out your IAC valve , that could be causing idling problems if its dirty.
    95' VS V6 Commodore
    May 2005
    VS_Pete_1's Avatar
    Dec 2007
    [QUOTE=Bex;1206815]Hi.. Its been stalling but only when im slowing down at the lights and just when im changing gears. Its an auto. QUOTE]
    Sorry mate missed the auto bit.
    95' VS V6 Commodore
    May 2005
    This is so frustrating, changed both sensors and its started stalling again :\
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    not that you want to keep spending money so get other views but airflow meters seem to cause all sorts of probs if they are stuffed like the probs you are having.
    VR Equipe II
    Mar 2008
    QLD
    CHANGE ECU!
    i had the same problem, drove me insane, changed heap of parts, checked heaps, nothin.
    change ecu and has been mint every since, i got my ecu from ebay, reco. haha for $50! yeww
    95' VS V6 Commodore
    May 2005
    VR Equipe II
    Mar 2008
    QLD
    mine was a occasional problem, only happened when it wanted to so i never saw it come up. same problem but.
  16. #16
    95' VS V6 Commodore
    May 2005
    yeah, same as mine. Changed the cam sensor on friday and all was running well, drove it over the weekend and it was stalling badly, now the last 2 days it hasnt done it. I did look on ebay and there seemed to be some ok priced ones, but i dont want to buy one and have the same thing keep happening. Do you think there is a way for Holden to test it to see if it is the problem??
  17. #17
    VR Equipe II
    Mar 2008
    QLD
    yeah its crap ay. i nearly sold my car bcoz i just got jack of it.
    i went to holden and they said that they could get me a test one for $50 bucks to have for a month.
    so really ur better off just getting that one on ebay.
    turns out they couldnt get me one anyway.
    man this is the guy i got mine off. $50 u cant really go wrong.
    HOLDEN DELCO ECU suit VS V6 & V8 - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 17-Jul-09 11:26:32 AEST)
  1. Crank Angle Sensor
    By Crofty78 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2009, 01:21 AM
  2. crank angle sensor
    By craigillz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2009, 12:38 AM
  3. Crank angle sensor?
    By sportyclansman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2008, 01:10 AM
  4. Crank angle sensor?
    By Bent_6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-12-2007, 10:22 AM
  5. crank angle sensor
    By play in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2005, 11:19 PM
