Results 1 to 2 of 2
Thread: VS V8 auto question
    VS SS
    Mar 2009
    Default VS V8 auto question
    Hi all, i have a VS Calais 5L, seems to be slipping (or flaring) between second and third, and even when kicking back from third to second, also when engaging forward gears from park or reverse, there seems to be a slight delay in engaging gear, no fault codes are showing and fluid is fine, anyone have any ideas? Thanks in advance.
    vs executive s1/ vz berlina
    Mar 2008
    it seems your pressure solenoid does not give enough line pressure , that why its flaring or seals, clucth plate inside worn out. try adjusting the pressure sol. by quarter in first and see how it goes. if not good, give another turn. you need a no. 15 torx bit to adjust the screw on the pressure sol.
  1. Auto question
    By smurf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2009, 10:22 PM
  2. vs auto question
    By rumbuck in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2009, 08:20 PM
  3. vs auto question
    Last Post: 02-07-2009, 12:38 PM
  4. Question about auto
    By krazyboris in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-02-2007, 07:06 PM
  5. auto oil question.
    By mahonas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2004, 10:24 PM
