Hey guys,
I have a 95 statesman and whenever i have my headlights/park lights on i get a "check tail lights" up on my dash, however, when i put my foot on the break it goes away... I assumed that the tail lights were faulty so i replaced them, however, its still happening. Any ideas? Common fault?
Yeah i did that aswell, they were fine too![]()
check your earths
Yeah the earths are fine. All the lights work no worries but it is saying that they arent :S
Are you using the right globes??
Yeah i am, I replaced them with the ones that were in there because at first when i first purchased it, it never had this problem. I happened about 2-3 weeks after i got it.
You need to go through a relearn process every time the battery is disconnected for the warning light to work properly as follows:
1. Engine off.
2. Reset BCM by pulling out the fuel pump fuse in the fuse/relay box under the bonnet. Wait for 30 secs and then replace.
3. Start engine and allow to idle.
4. Turn on parking lights. Wait 5 seconds.
5. Press brake pedal. Wait 5 seconds.
6. Turn off parking lights. Wait 5 seconds.
7. Turn off engine. Release brake pedal.
8. Relearn completed.
the same thing has just happened to me in a vr stato, gonna try this process tomorrow and hope it works
