Results 1 to 6 of 6
Thread: charcoal canister vacuum llines - where do they go??
    vs s ute series 2
    Sep 2007
    Default charcoal canister vacuum llines - where do they go??
    g'day guys..
    does anyone have a pic / diagram / idea where the lines from the cahrcoal canister run to?
    i believe one runs from the fuel tank, and one runs to the throttlebody?
    and the other?
    cheers
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    the one running from the fuel tank to the canister (the fattest line) is the fuel vapour line
    you also have a vacuum running to the throttle body from the purge control valve on top of the canister (thinnest line)
    there is also a second one running to the throttle body, this is (I think) the vapour line after coming out of the canister. (2nd thickest)
    on the bottom of the canister there should be a hose that connects to nothing, this is just atmospheric intake.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    94 VR Statesman
    Aug 2006
    yeah depends VS have a different setup to VN,VP,VR but its all pretty straight forward
    vs s ute series 2
    Sep 2007
    well do you know where they run on a vs?
    i have located the one from the fuel tank. and the top smallest line runs to the purge solenoid behind the engine, and the third line has only a short 2inch hose on it which just hangs in the engine bay. Where does this one go?
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    if it just hangs it probably just the fresh air hose
    The hall of fame:
    ಠ_ಠ
    vs s ute series 2
    Sep 2007
    its not the stmospheric line, it is the line to return the vapours to the engine from the tank, but i dont know where to hook it up to? TB? purge solenoid?
    can anyone help?
  1. charcoal canister
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2009, 09:57 AM
  2. charcoal canister piping
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2008, 10:39 PM
  3. Can anybody tell me where the charcoal canister is on a vz ss ute?
    By nealie84 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-04-2008, 10:40 AM
  4. What is a charcoal canister good for?
    By johnnythaboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2008, 10:26 PM
  5. charcoal canister
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2007, 04:01 PM
