Results 1 to 4 of 4
Thread: BCM swapover in vs, is it simple?
    VS Commodore series II
    Mar 2009
    Port Macquarie
    Default BCM swapover in vs, is it simple?
    Hey,
    Ive been looking into power windows so i can get better looking doortrims....anyway..
    i was told that to run power windows ill needs a medium/high range bcm, and mine is low range... so it will need to be swapped over.
    now my question is, will it all just unplug/unscrew, then the new one will screw in, and all wires attached back to the med/high range one?
    will it run properly? is a new bcm all ill need to swap? will it mess up other things?
    if it runs smoothly, all ill need to do is unplug the low range, plug in the med/high range and then replug in the plugs, then get the new loom from the power windows and run it to it.
    cheers in advance
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    You will also need the keyhead to go with the new bcm.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Mar 2009
    Port Macquarie
    oh really? well i was told i will need medium or higher, thats such good thing to hear, wont need a new key or swap anything over.
    thanks heaps hopefully it works for me
  1. M76 question...just a simple one
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-01-2007, 09:37 PM
  2. just a simple mod
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2006, 09:49 PM
  3. boot garnish swapover
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2006, 06:18 PM
  4. One simple Question
    By fishymaster in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2006, 12:22 PM
  5. 3 Window cluster swapover - Can it be done?
    By davus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2005, 10:43 PM
