looks like you have a flat battery..
Electrical come on, but when i turn the key fully it makes a clicking noise and the electrical s click as well, the fan belt rotates slightly. headlights ect come on. the engine doesnt kick over at all.
Any ideas??
Yeah flat battery and or bad starter motor
but all the electrical s and lights are working
there is a clicking noise coming from under the bonnet, its constant when the key is fully turned
are there any other possibilities?
Go Hard Or Go Home
the clicking noise is coming from the starter motor, they make that noise when there is not enough amps in the battery to turn it.. Oh there is one other thing, check the earth lead that connects between the motor and the body, sometimes where it bolts to the engine the bolt comes loose and it looses its connection causing the starter to click..
flat battery, water pump, or starter motor.
most likely flat battery though mate, just give it a jump start, let it run for like 5 mins, then you should be fine.
turned out it is the battery got a jump from a mate and now its fine
havent had a flat battery in that long forgot what it was like lol
Thanks guys!
Go Hard Or Go Home
Listen to what these guys said. It is either the starter motor or you have a flat battery.
It takes a lot of power to turn the starter motor over. Just because the headlights come on and the radio works, doesn't mean the battery isn't the problem.
Good luck
EDIT: 4 minutes too late, now I just look silly - well sillier than normal. Must learn to type faster.
had same problem and i changed battery, id had been mucking up for a while, but i tested it just before my driving test and didnt start so had to get a battery asap, got one for 120 bucks....
