Has anyone taken out the standard 59lt tank and put in a 73lt long range tank in there vs? if so what problems have u encountered?![]()
should be an easy swap as long as it comes with the sender unit in the tank and the straps also you will have to flick a switch on the back of the cluster
Im running into problems with holdens tank strap setup have u actually done it before?
Did you get the straps with the tank? when I put A 73l VS SS tank in my Vp I to cut a Vn strap and join to a Vs strap plus lengtheh it by 17cm on the passenger side ,but you should be able to use a vs statesman strap as it should be standard size
