Results 1 to 9 of 9
Thread: Annoying vibration noise.
    VS commadore V6
    Mar 2007
    Default Annoying vibration noise.
    Hi guys, I have a vibration sound that comes and goes but very bloody irritating to say the least.
    It comes from the front left hand guard, sorta a humming sound, so when it happened again yesterday i got out the car and found that it seems to be comming from a small metal pipe that runs inside the left hand guard and goes out to the brake assembly,[ i guess a brake fliud tube ] when I held it the noise stopped, I notice there is a metal clip that holds it into position and feels very tight, so I am wondering if there should be a rubber that suppose to be inside that clip that may have fallen out and causing this vibration sound.
    any help is appreciated,
    thanks
    Rony
    VS commadore V6
    Mar 2007
    If possible could someone please have a look at their brake fliud tube that goes along the front passenger inside of guard and see if there is a rubber in that clip, thanks heaps if someone could have a look for me.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    G'Day Ron, no rubber I can see but there is a clip - pix attached and hope it helps..
    Attached Thumbnails Attached Thumbnails Annoying vibration noise.-brakeps.jpg
    VS commadore V6
    Mar 2007
    Thanks very much Hako and thanks for the pic as well, I guess I will have to explore more into this, might try another rubber gromet that the tube goes through to the brake assy.
    thanks again mate
    regards
    Rony
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    it might be the source of the sound, but prehaps not the source of the excessive vibration, good luck with it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe the passenger side engine mount has sagged and is either metal to metal or the silicone inside the mount has leaked (the silicone is supposed to dampen vibrations).
    VS commadore V6
    Mar 2007
    Thanks guys, I finally worked it out, it was a loose bolt which held on a bracket for the gas conversion equipment, on top of the front shocker they had mounted a bracket, the nut was really loose, tightened it up and the vibration went away, thank god, what a pain in the but it was.
    When I held the brake fluid pipe my hand must have cushinged the vibration to quite it down, one major pain in the arse solved
    regards
    Rony
    E46 M3
    Jun 2009
    VS
    Oct 2008
    Hahaha agreed
  1. Annoying rubbing noise coming from rear
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 06:03 PM
  2. annoying noise from dash after turbo timer hooked up
    By sik-holden in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2008, 08:05 PM
  3. Annoying moaning noise from engine
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2006, 08:44 AM
  4. Annoying Noise
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2006, 09:58 PM
  5. Annoying Noise
    By mza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2004, 10:36 PM
