Results 1 to 19 of 19
Thread: Engine problem!!!!!!!!!! Any help?????
    Ms 5ltr VK is offline I drive faster than boys!
    VK Calais 5ltr
    Jul 2009
    Default Engine problem!!!!!!!!!! Any help?????
    Hey guys, I have a VS Acclaim wagon.
    It's done 320,000 and my fiancee and my brother just changed the head gaskets ( it had a blown head gasket when we bought it )
    This is the story.
    Got the car, drove it round for a few days to see how it went ( local driving ) and then one day, it started running rough as all hell.
    That's when the head gaskets got done.
    They got it all back together, and it's still running like crap.
    There has been new leads, and spark plugs put in, and the oil is gonna get changed on the weekend comming up.
    There is spark in every connector in the coil pack aswell.
    My fiancee cleaned the injectors today, and put it all back together, and it still runs like shit.
    It's idles, but rough.
    Any ideas on what it could be???
    There is a tiny bit of water in the exhaust, but dries up when the car gets warm.
    Also, there is normal pressure in the radiator hoses ( can't really squeeze it )
    So without having any electrical testing equiptment, i am at a dead end trying to work out what it is.
    Thanks for having a look, hope you can help.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    first thing i would check is error codes.. in the how-to section its one of the first 3 stickied threads. here: Checking error codes VR/VS (Revised)
    this should hopefully point you/us in a direction. post up ur find
    E46 M3
    Jun 2009
    could be anything, especially with that many k's on the clock
    first step would be to see if theres any error codes stored on your ecu... all you need is a paper clip to do it. pretty sure there is a thread on here somewhere that shows you how.
    if that shows up anything, tackle that issue first...
    *edit - ephect beat me to it... i must say, excellent advice mate *
    VK Calais 5ltr
    Jul 2009
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    stuffed coil or DFI
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the heads were not skimmed before refitting it may still be a head gasket leak or an inlet manifold leak. Timing shouldn't be off as it is not adjustable.
    I'd pull all the spark plugs out and inspect - if one or more look dramatically different from the others that may point to a head or inlet manifold gasket leak. Double check the plug leads are on the correct plugs/coils as it is easy to get them mixed - this may allow the car to run but with a miss.
    I'd also do a compression test while the plugs are out and see if there is any variance between cylinders.
    Good Luck.
    VK Calais 5ltr
    Jul 2009
    Thanks heaps everyone for the info and advice, as we haven't got any testing equiptment here at home, i'm just going to take it to a local mechanic and see what he comes up with.
    I thought it may have been an inlet manifold leak aswell, but i'll guess i'll find out sooner or later.
    Can't beat the old carbie V8'S!!!!!!
    Cheers guys!!!
    I'l let you all know what the problem was.
    vs alclaim II
    Jun 2009
    hey guys im new to this whole forum thing
    but im having simmilar problems with my series 2 vs aclaim
    just did plugs leads and oil change but the engine light has just come on after a few weeks and its running like a unfit dog
    want to know what the engine light could mean
    i have asked a few freinds they seem to think its the crank angle sensor ???
    please help
    Vs series 2 stocker
    Hmmmm
    A blank canvas
    Nothing better
    VR 3.8 1994
    Jul 2008
    Im having the same problem with my 95 vs exec.
    on Sunday i replaced the intake manifold gaskets (valley gasket). when i was finished i turned on the car and it was running like it had a miss.
    so today i tried to do a bit of problem solving and was thinking it could of even been a vaccum hose come off but everything looks alright. i came to the conclusion that maybe there is coolant leaking into one of the clyinders because there is a fair bit of water coming out of the exhaust. so on the weekend i might pull everything apart and re-do everything.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by flossy.08 View Post
    please help
    First thing is to do a codes check which is very easy:Checking error codes VR/VS (Revised)
    Then tell the forum of the past history of the car - any work recently done, overheating, uses oil???....things like that.
    ps...you may get more input if you start a new thread...and welcome!
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    try cleaning the throttle body completely... meaning take it off use carcy cleaner and spray all the blak stuff out of the bore and also clean the Idle air control and the passages. some people swear by this but it doing do much for me.
    1988 VL Commodore (Wagon)
    Jul 2009
    It's probably the manifold, do you have extractors or a stock exhaust? I bet you have a stocky. I had a similar problem with two other cars and this turned out to be the problem.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by Jimmyblonde View Post
    so what was the problem exactly? u saying the stock manifold is the problem? that is rediculous, holden released the car with stock manifolds and they were fine from factory.. where are your facts?
  15. #15
    vs alclaim II
    Jun 2009
    thanks for your help guys im a apprentice deisel mechanic ... so when i go back to work tomoro im goin to
    try checking the codes
    and also im from newcastle im lookin into gettin my droopy headliner fixed dose any one know where i cant get it re upolsterd or buy a new one and how much?
    Vs series 2 stocker
    Hmmmm
    A blank canvas
    Nothing better
  16. #16
    vs alclaim II
    Jun 2009
    the past history ov the car
    welll basicaly i picked her up for a steal 2 grand off a bloke from work
    its got 195*** thou on the clock
    i changed the engine oil and coolant and leads and plugs basically when i got it
    ohh and it had a big corriosion gouch in the rear exhaust ... so i took it off and had no exhaust on it for 3-4 days but took it too carline mufflers and they hooked me up with a new rear muffler ..
    thats the car history that i know ov
    thanks
    Vs series 2 stocker
    Hmmmm
    A blank canvas
    Nothing better
  17. #17
    VS exec
    Jun 2009
    bong from the gong
    Quote Originally Posted by ephect View Post
    I think he might be suggesting if its stock the manifold gaskets could be stuffed
  18. #18
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    sounds like u've got some skills being a mechanic , heres the how-to for the headlining HOW TO replace headlining - Very detailed
  19. #19
    vs alclaim II
    Jun 2009
    well only a 1st year . and mainly know ... nitty gritty ov cumming diesel engines commodore engines .. stump me at times and i wanna do things right beeing my car lolz thank mate
    Vs series 2 stocker
    Hmmmm
    A blank canvas
    Nothing better
  1. VS Engine into VR - Problem
    By Dream Commodore in forum Electrical Wiring / Questions
    Last Post: 30-01-2009, 04:04 PM
  2. VE SS ...Engine problem
    By BOY1236 in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-01-2009, 11:50 AM
  3. engine problem
    By Budz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-09-2008, 08:18 PM
  4. engine bay problem
    By vr_owner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2006, 12:10 AM
  5. VN V8 Engine Problem
    By jwk87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2005, 10:22 AM
