Results 1 to 3 of 3
Thread: Changing ignition barrel light
    Verynice's Avatar
    Verynice is online now Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Default Changing ignition barrel light
    quick question, searched forums but didnt find anything....
    How do you replace the ignition barrel light? (the one that you use to see where you put your key in)
    Thanks
    VS SS
    Mar 2009
    easy job, just unscrew the plastic steering column covers, drop the bottom one and you will see the small light, just turn it to the left till it pops out and change the globe, then reassemble.
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    thanks man!
  1. Changing VY ignition barrel
    By Carlton95 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-01-2011, 06:27 AM
  2. ignition barrel
    By jeddabum in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-11-2007, 10:00 AM
  3. Ignition Barrel
    By ElDubya in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2006, 06:45 PM
