Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: ultra lows and still very high?????
    VR Equipe II
    Mar 2008
    QLD
    Default ultra lows and still very high?????
    hey guys
    i just found out that i have ultra low king springs in the back
    the code is KHPR-20SL and i checked it on kings and it says that there ultra lows.
    heres the problem
    see how high it is in the rear... HOW IS THAT ULTRA LOW!!!!!
    whats the go? can someone help me with this?
    only thing i can think of is compressing springs...
    thanx guys
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    what shocks u running? is it IRS rear end?
    VR Equipe II
    Mar 2008
    QLD
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    hey mate, sorry it's off topic......did you fit the surrounds?..u happy with them?...
    check if they are in the spring housing properly..
    VR Equipe II
    Mar 2008
    QLD
    Quote Originally Posted by S2_VR_ View Post
    yeah man i did thanx, just check my thread.
    and yeah i got em pro fitted so should be done properly
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    can only suggest that they have labelled the springs wrong, seen it a few times..
    im sure a couple of members that have had this problem will post up soon.
    VY SS
    Jun 2006
    Albany
    i got the same springs in mine and looks about the same as yours, thats the problem with live axle they are harder to get that slammed look. you could pull the spring insulators out or buy thinner ones
    VR Equipe II
    Mar 2008
    QLD
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    just a thought, what size are those wheels ? if the rolling diameter is bigger than standard then that will raise the car.
    If not , take the springs out and measure them and get kings to check if they are the right height for ultra lows. or if they are the wrong springs.
    VR Equipe II
    Mar 2008
    QLD
    VR Equipe II
    Mar 2008
    QLD
    VY SS
    Jun 2006
    Albany
    VR Equipe II
    Mar 2008
    QLD
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
  15. #15
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    theres is definatly somthing fishy here I`ve got SL in the front and SSL in the rear and 18`s and it sits lower than that, the tread on the rear is in the gaurds.
    You now have to wiegh up your options pay for compression or get them replaced and refitted at there expense (if it indeed is mislabled), could be hard to get it out of em though, good luck.
  16. #16
    VR Equipe II
    Mar 2008
    QLD
    had the springs in for awhile ay 4 months possibly, so theyve had time to sag.
    thats what i mean, every ultra low car ive seen it tucks tyre, so thats what i cant believe that there ultras.
  17. #17
    Feb 2009
    yeah they will settle soonish..... damn i want sedan ultra's for my Wagon
    EDIT: ok 4 months settle time.....they're done
  18. #18
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    they will not settle now.. they hardly settle much after they've been for a quick spin round the block after fitment. let alone 4months later
    definately the wrong springs
  19. #19
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by holden-4-life View Post
    ahh kk i was gunna say if u just got them wait a month or too
    my pedders ssl rear just tucks and it hasnt even bed in yet, somethings deff up man
  20. #20
    greenacc's Avatar
    VE Berlina
    Jul 2008
    i got 18s, i got 15s in the shed, where should it sit at if i put those on?
    Just roll one of your 15's up beside the 18's. If the tyres are the same height then it would sit exactly the same. ( if your speedo is accurate with the 18's then don't bother )
  21. #21
    LowVtWagon's Avatar
    LowVtWagon is offline LowVtWagon
    Holden VT Acclaim Wagon
    Dec 2008
    country
    Hey guys, doesnt matter what size wheels/tyres u have, they are pretty much the same size. Our VT came out with 205/65R15 standard and we have fitted 245/35R19's. The difference is only 7mm in rolling diameter!! Not much at all. I reckon the same as "ephect", wrong springs. But better to be sure and take them out and measure and get in contact with king springs and find out their measurements!! Good luck
  22. #22
    VR Equipe II
    Mar 2008
    QLD
    ok then, i think i mite just ring kings first see if its even possible for a mistake, maybe they can do something about it.
  23. #23
    E46 M3
    Jun 2009
    for a live axle that looks about right... they really aren't that low
    measure exactly how much lower you wanna go, take your springs out, take them somewhere to get them compressed by your measured amount, then wack them back in
    is the cheapest, easiest and surest way to ensure you'll be happy with the finished look... don't buy bigger wheels to try make your car look lower
  24. #24
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    ultralow springs are low, and they tuck tyre full stop. its happend a few times where the springs where incorrectly labelled. that height is superlow.
  25. #25
    E46 M3
    Jun 2009
    my bad, i thought they were super low... still, short of having them swapped over, same applies
  1. [VIC] swap VT-VZ REAR ultra lows for super lows
    By jimmyd17 in forum Swap / Wanted to Buy / Trade
    Last Post: 23-05-2009, 12:24 PM
  2. [VIC] Super lows & ultra lows
    By somerandom in forum Swap / Wanted to Buy / Trade
    Last Post: 29-01-2009, 04:49 PM
  3. Swap: super lows for ultra lows - VN sedan - in Perth
    By savage1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-08-2008, 12:47 PM
