Results 1 to 3 of 3
Thread: cracked head?
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Default cracked head?
    I have a 99 v6 ute that i have found has water in one of the cylinders and therefor wouldn't crank over, I took out the spark plug and got rid of the water but I want to know which is the best stuff to use to try and seal up this crack?, I know I have to put another motor in but in the meantime I have been told to use "iron tite", someone else said "chem weld" and then another blokes told me to go with the "Wynns" stuff, any ideas on which is the best way to go at this point in time?, as i say it's only needed for a few weeks until i find another motor...
    Cheer's ian
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Iron-tite I've heard is good but I'm not sure it will fix a leak that big....but certainly worth a try. I think in your case you would add the stuff then run the engine with the plug out so that the sealant plugs the crack.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Pitty its not something simple like the inlet manifold gasket, good luck with it.
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. How to tell when you have a cracked head
    By Pub247 in forum Jokes/Humour
    Last Post: 04-05-2009, 07:57 AM
  3. cracked head
    By danos in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-07-2006, 10:19 AM
  4. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  5. Cracked Head?
    By Joshy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2004, 04:11 PM
