Results 1 to 14 of 14
Thread: Heater Ducts broken!?!?!
    VR executive
    Mar 2009
    Default Heater Ducts broken!?!?!
    The air ducts in my VR commodore have just stopped changing..
    I can't get the air off my feet and change it to my face. I've tried pulling out the console and re-plugging it all but it doesn't seem to fix it..
    I can adjust the heat, just not where the heat comes from..
    Help?!?!
    Thanks in advance.
    VR executive
    Mar 2009
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Having an exec you would just have the regular dials (not climate control) so the first thing will be to check the vacuum canister which is a black plastic ball behind the front bumper on the passenger side. Make sure all vacuum lines are still connected and follow them back to the fire wall and check all vacuum lines. 99 times out of 100 it just a lose vacuum line.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    VX SS M6
    Jun 2005
    under the radio there is a vaccum controler for the vents its that, mine has the same prob.
    Mar 2005
    South Coast, NSW
    The OP has an exec, therefore non climate control. The non climate control air con doesn't have the vacuum solenoid you're referring too. Just good old fashioned vacuum hoses.
    VR executive
    Mar 2009
    i've pulled out the whole unit under the radio and had a look at it, put it back in and it still doesnt work.. i'll check the vacuum hoses though. thanks guys!
    VX SS M6
    Jun 2005
    Quote Originally Posted by Scooter79 View Post
    oh i just thought they all used the same thing
    Mar 2005
    South Coast, NSW
    What?
    VR executive
    Mar 2009
    hmmm... What am i looking for? is it like a ball of steel behind the bumper? if so, what exactly do i look for to try and solve the problem?
    VX SS M6
    Jun 2005
    What?
    what do you mean what???
    i said i thought they all used the same vacuum solenoid thingy...
    Mar 2005
    South Coast, NSW
    Quote Originally Posted by vrcommozone View Post
    A black plastic ball, round canister, whatever you want to call it, behind the front bumper on the passenger side. It's about half the size of a soccer ball. That's what holds the vacuum pressure needed to direct air flow.
    Quote Originally Posted by VSIIBerlinaL67 View Post
    Sorry but simple spelling mistakes make things difficult to read. The vents for a climate control equipped car are controlled electronically. That's where the solenoid you're referring to comes into play. In regular air con like in the executive models, the vents are controlled by turning the dial. Have a look at the back of a manual air con control box and you'll see colour coded hoses for each vent. Turning the dial opens and closes the vacuum hoses and therefore no solenoid is required.
    That's why I don't get why people keep asking how to do a climate control conversion. Whats the point. The manual ones have nothing electronic that could fail.
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    also check the vaccum hoses, trace them all from the vaccum ball, to the motor, thru the fire wall & intothe back of the control, make sure they are all pushed on correctly.
    I pulled my hair out for ages chasing the same problem in my Calais, had the entire console & dash out, the issue was the hose had come off in the engine bay.
    VR executive
    Mar 2009
    Quote Originally Posted by NORTI View Post
    Had exactly the same problem, it was a hose in the engine bay.. must've unplugged it after I took off the throttle body
    thanks guys, all working now!
    VX Berlina VT Calais
    Mar 2009
    Default VX Berlina
    Same Heater problem in my VX
    Display changes but still only blows on w/screen.
    vacume hoses on passenger side do not seem to be getting any air from that little black box in the foot well?????
  1. Broken heater!!!
    By 91vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2009, 02:50 PM
  2. Broken Heater and Air Conditioning (VR exec)
    By Jeff T in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2007, 12:59 PM
  3. Heater blower fan broken - VN
    By Tekit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 11:38 PM
  4. heater tap broken is this a common thing
    By anotherstockvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-02-2006, 04:50 PM
  5. removing air ducts
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 04:42 PM
