Results 1 to 4 of 4
Thread: coolant capacity
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Default coolant capacity
    Can someone please tell me how much water a vs v6 ecotec holds please?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As accentstencil says, 12 litres...however, if you drain by pulling the lower radiator hose off you will only drain about 5 litres - to drain the full 12 litres you need to remove the knock sensors. (this isn't what you asked but I thought I'd throw it in as well!)
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Good man, thanks again...
  1. sump capacity
    By ab56452001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2008, 11:23 AM
  2. Engine Capacity...
    By azkwazere in forum The Pub
    Last Post: 15-04-2006, 11:44 AM
  3. vz ss ute fuel capacity
    By hsv_chick in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-08-2005, 11:26 PM
  4. Coolant capacity VP V6
    By Xonar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 07:05 PM
  5. engine capacity
    By ralph in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-03-2005, 09:26 PM
