Results 1 to 6 of 6
Thread: VS V6 Automatic Problem
    VU II SS, HJ Premier
    Jul 2009
    Default VS V6 Automatic Problem
    Hi,
    I have a friend that has a VS Automatic that is having a problem on take off. When she tries to take off, the car will just rev until about 1500-2000 rpm before it will move. Once it is moving there is no problem.
    The transmission fluid is very dirty and when she took it to the transmission place to ask, he said that there was no point servicing it as it would be a stuffed converter and that a service would make no difference. He also said that as the converter is damaged there would most likely be much more damage to the box itself and that a rebuild at about 2500 would be required.
    He wants $55 just to plug the scan tool in to check for fault codes to confirm the problem. I am not close enough to be able to go over and check the fault codes using the paperclip trick.
    I did a search for similar problems but just wanted to make sure.
    Thanks.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like the car is in Limp Home Mode (restricted to 3rd gear and reverse). I'd get het to get a 2nd opinion as "off hand" statements are sometimes designed to freak the customer out. If the 2nd place confirms the first then she needs to decide whether she wants to spend $2500 or sell it or fix it via a wrecker. Maybe you can walk her the the 'paperclip trick' over the phone.
    Hope it turns out OK and welcome to the forum.
    VS exec
    Jun 2009
    bong from the gong
    E46 M3
    Jun 2009
    ^i agree
    fair possibility the transmission guy would have had dollar signs popping out of his eyes when she rocked up, sh*ts me that. try 5L of fresh dexIII and go from there...
    Jul 2009
    Thanks for the replys.
    Just got them to test it and it produced 12, so all ok there. Also got them to test it by going 1-2-3-D and it goes absolutely fine then.
    Its only when you take off in drive. By the revs sounds like it could be in limp home mode.
    Hopefully only dirty fluid.
    vs-6 is offline Raptorcharged VS
    VS S pac V6
    Jan 2008
    perth claremont
    when you checked codes did you wait for a while you get the first code 3 times then it may flash somethign else if its a stored code
  1. Problem with headlights when set on automatic
    By alyshawassa in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-04-2009, 10:40 PM
  2. VN Automatic 1st 2nd ok 3rd problem
    By madmatt2006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2008, 11:33 AM
  3. got a new problem with automatic
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2006, 09:43 PM
  4. Automatic Transmission Problem (VXII)
    By myberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2006, 04:27 PM
  5. Automatic Transmission Problem
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 09:52 PM
