Results 1 to 12 of 12
Thread: pat number 92042709
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default part number 92042709
    I`ve got a genuine rear ss lip and it does not seem to fit properly I`m beginning to think I have a VN SS rear lip but am unsure that is the pat number.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by whiteknightVR94 View Post
    The part number fails to show up on my data base for VN or VP
    and 3 Dangerous non ABS VN's
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ill have a look tomorrow for ya when im at work .
    probably supersedes to another part number
    Boonz's Avatar
    Jul 2005
    these are the part numbers for the ss lip
    RH skirt- 92044030
    centre- 92044029
    LH skirt- 92044031
    that partt number you ahve doesnt even appear in holdens catalogs. so i dunno what its off of :P
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Wow ok, got the lip on and its just about 1-2 cm out so the joints are appart a bit its plastic and 3 piece so I don`t know WTF its off if not a SS.
    VY SS
    Jun 2006
    Albany
    VS l67 statesman
    Dec 2008
    Had the same trouble with my factory plastic Vp rear lip I think they tend to shrink with age
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by vsl67 View Post
    Wow when your right your right, its is the right lip and has shrunk anyway I got it on and it looks passable I`ll put up some pics 2morrow anyway I am also putting on the side skirts and am mind boggled and P`d because they also have this gap, anyone else had this problem as I`ve never heard of this before and was wondering how to combat this would you need a direct swap within a day from car to car as I would assume it only shrinks when removed.
    E46 M3
    Jun 2009
    is pretty normal mate, the rear centre skirt has about a 5-10mm gap where it joins to the rear side skirts. same goes with the side skirts... doesn't really look that bad, some would even argue it looks like its meant to be like that
    there should be enough overlap behind the joint where they slot into eachother to cover it up tho (if you get what i mean)
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    about the gap yes I do get that, though when you say meant to be like that do you mean factory? because the SS when factory fitted have no gaps I checked.
    E46 M3
    Jun 2009
    not sure if they came from factory like that, how did you check?
    but any genuine second hand ss skirts you buy these days will have the gaps. doesn't look that bad at all, one of those things you'll just have to live with
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Yer I`m over it I can live with it, I checked by looking at any SS.
  1. bcm number
    By buster1192 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2009, 06:23 PM
  2. V.I.N Number
    By Super Coach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2006, 04:26 PM
  3. vin number
    By proto_vr in forum General
    Last Post: 07-08-2006, 11:55 PM
  4. vin number
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-06-2005, 05:23 PM
  5. vin number
    Last Post: 04-06-2005, 11:12 PM
