Ok, my VS Ute out of the blue started laboring and jerking at low rpm (below 2.5k) and also lacks power (slow to accelerate even in 2nd with throttle wide open).
The engine seems to run fine when the vehicle is in neutral or park. It also runs fine when cruising at 2.5krpm + with minimal throttle open.
The moment the car comes under load it starts jerking (the engine), sorta like its missing or running really really rough. Like when you've got a manual running too slow for the gear you're in.
I thought it might be the fuel filter but I just changed that and there is no improvement.
A side not however, when I was changing the filter no fuel poured out once I disconnected the filter. I switched the ignition into run and the pump was able to push a fuel out easy enough (didn't seem to be a lot though, the fuel pump on a vl i used to own pumped more out when stuck in a bucket of fuel).
When the fuel filter is removed fuel is supposed to run out right? There is about 2/3 of a full tank there.
Any help would be very much appreciated. In it's present state the vehicle is just not usable and I really really need it back on the road ASAP.
Thanks!
sounds more like a spark issue to me especially since its missing under load,,
if it was lacking fuel pressure it would struggle at higher revs ,also
id be checking plugs and leads mate
Hmmm. I discarded spark out of hand as the leads n' plugs were changed at the last service only 5000km ago. And the coil packs less than a year old as well (or so I was told when I purchased the vehicle)
its all worth checking mate
generally when theres a miss underload its due to spark issues
Fuel should have sprayed out when you changed the filter indicating there is pressure in the line - if it didn't then it could indicate the fuel pressure regulator is stuck open and fuel is being supplied to the fuel rail/injectors at a greatly reduced pressure - maybe this is the cause of your problem. I've found that even after following the instructions to "de-pressurise" the fuel system that residual pressure in the lines will still cause fuel to spray out. Also I've found that fuel will not 'syphon' out with the filter disconnected unless you have a near full tank (sedan).
To check this you could loosen the fuel hose to the filter just after turning off the car - the fuel should start leaking out till the pressure is reduced.
The symptoms of reduced fuel pressure can vary with problems at low or high revs (injectors squirt more at high revs)
No fuel leaked out till I had the fittings fully disconnected. And then it only just barely dribbled out. That was after just running the car though and I didn't prime it again before taking the fitting off.
I just double checked by priming it and then loosening off the fittings and well, all I can say is thank god for safety glasses.
Ok, so it's not the fueling system. That leaves spark. Cool.
Also, could the transmission be causing this sort of issue?
Try this mate,
With the engine off, remove the first 2 leads of the first coil pack and then start the car, a spark should be jumping from metal tip 2 tip on your coils, if the spark jumps anywhere else (like downwards or onto any other part of the coil) then that coil is fualty and needs replacing! Either way mate hope ya get it sorted & best of luck
Edit: obviously if the first coil pack is fine and works well then turn the engine off, replace the leads and move onto your 2nd then 3rd coils![]()
MY RIDE 96 calais
http://forums.justcommodores.com.au/...96-calais.html
ALSO MY 1972 VALIANT CHARGER IN THE BUILD
http://forums.justcommodores.com.au/...t-charger.html
[QUOTE=mulligan-can;1218407]No fuel leaked out till I had the fittings fully disconnected. And then it only just barely dribbled out. That was after just running the car though and I didn't prime it again before taking the fitting off.
The fuel in that line immediately after turning off should be at about 35 psi - greater than the air pressure in your tyres - it will spray like a pressure pack....dont smoke!!
Good Luck.
Theres a similar trick to the one above to check if one of your leads is rooted, take a spray bottle at night and spray mist around the heads of your leads to see for any spark jumps.
Thanks guys for all your comments above I used a process of elimination to come up with the culprit which was the plug leads. The symptoms were exactly the same as mulligan-can's VS Ute. I have a VT Calais Supercharged and have saved myself a lot of time and money. I replaced the leads today and the engine runs beautifully like it always used to. I was getting horrible shudders and missing under load at 1700 RPM in top gear at 100KPH when slowly depressing the accelerator, also the engine was hunting at high RPM under harsh acceleration. Very happy now, I used the old plugs leads as a guide and laid the new leads out in the same fashion and transferred the clips over worked a treat. A word of caution, I tested the resistance of the old leads and they were fine, so don't be sidetracked if you get a good reading, they can still "leak" it seems. Of interest the local garage told me it was "an injector problem" and should clear with a bottle of injector cleaner.
my car seems to be doing the same thing...it labours at low rev's most usually in 4th gear changing to 3rd it shutters and loses power until i let my foot off the accelerator and it drops into 3rd, and when i take off from a stand still its got a flat spot for about 2seconds then takes off.....would this be the same kind of issue guys?
That is awesome found a dead coil pack in 2 seconds on my sons v6 vs
If you don`t want to break it , then don`t bring it out to play with it !
Hey guys, I recently bought a 93 holden jackaroo.
I've got the same problem with it struggling at low revs.
So Ive changed the spark plugs, bought new leads and did the coil test and there were all fine... So now what?? I have no idea what could be wrong? Any tips?
Err, Find a Jackeroo Forum??? I have absolutely no idea about them......
MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
