1. just got told my oil pressure switch is leaking? how much to replace, and is it easy to do?
2. Suspect Rocker Covers leaking? fixing up $$??
you could take care of it all for around 50-80 bucks if you do it yourself
easy?... yep![]()
where abouts to get the switch and whats involved?
Any repco/bursons etc should have them on the shelf. Wont be too expensive. Easy as to change yourself.
Just unplug the cable from it, unscrew it, put teflon tape on the thread on the new one and replace.
Oil pressure switch is located right near your oil filter.
Rocker cover gaskets are easy too, same place, wont be expensive
i did mine a few weeks ago $20 from bursons
easy just abit messy with the oil but last a long time
how tight does it have to be? is where u grab ahold of the switch to tighten meant to be flush with the space to put it in?
in such a hurry to take it off i forgot how tight it was :P
you will no when to stop because it wont tighten up anymore
