Results 1 to 7 of 7
Thread: starter motor scream!!!!
    VR Executive
    May 2009
    Default starter motor scream!!!!
    Hey guys i have a auto vr which i converted to manual with a series 1 box and starter motor
    the problem i have is that wen i go to start it the starter screams like its hitting the flywheel or going to far befor it engages
    normally i would just buy a new one assuming the starter is fubared ..
    but i find if i move the gearstick from side to side in neutral or putit in first or any other gearwith foot on the clutch it starts most of the time with out a problem
    any one had this issue before or no what it could be
    also the ring gear on the flywheel is fine
    and wen i fitted the starter i pulled it out by hand and it seemed to engage the flywheel fine so am unsure wat is going on..
    any help muchly appreciated
    Apr 2005
    I've got the same drama with my dunger VN S1 jam cake. What's the battery connections like at the battery and at the starter? And the ignition wire?? If it's that, then I could be bothered fixing mine. Otherwise it's gr8 for scaring the crap out of grannies when you try to fire her up....
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    If youre talking about when hitting the key and the starter motor lets out a loud scream but doesnt turn the engine over, then the one-way clutch within the starter motor is worn/wearing out. Mine does it occasionally but not often enough to rebuild/replace it yet.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    vp series 2
    Jul 2009
    Default starter motor prob
    Quote Originally Posted by BOOZTJUNKEY View Post
    Could be a short in the "pull-in" coil in the starter motor's solenoid - possibly its motoring just on the "hold-in" coil. These intermittent probs are always hard to pin point. Check with a sparky and see what he says. Regards Col
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It sounds like the solenoid isn't engaging the pinion fully with the ring gear before energising the starter - this makes the pinion spin before it engages and makes a horrible metallic scream - if not fixed it will evenually chew the pinion and/or the flywheel up.
    This would also tie in with you noting that it does not do it when you have the foot on the clutch - the pressure against the clutch forces the flywheel/ring gear closer to the starter pinion and this allows it to engage before it starts spinning resulting in no scream.
    I read somewhere that manuals have a different starter to the auto although you say you have this already.
    So basically I reckon the starter pinion is not engaging properly with the ring gear. Good Luck.
    32pseye is offline 32pseye
    Vr aclaim
    Apr 2007
    warrnambool
    Quote Originally Posted by hako View Post
    Yes for manual you need i high torqe starter motor
    VR Executive
    May 2009
    thanks 4 all the replies i think ill just replace ity and see wat happens the starter motor itself was outdoors bolted my engine on the for i dont no how long ...
    ill just look for a vp auto one there the same...
    and yes i have the delco remy high torque starter..
    the connections should be fine they worked fine wen the auto was in altough one of the the accessories wires coming of the battery to the fuze box was cut it was solderd back togethr lol
    thanks again
  1. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  2. [SA] Wtb: vn v8 starter motor
    By shy304 in forum Swap / Wanted to Buy / Trade
    Last Post: 22-12-2008, 05:53 PM
  3. Starter motor
    By HAZZA-VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2008, 08:38 AM
  4. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  5. VG ute starter motor
    By oldsurfiepete1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 12:58 PM
