Results 1 to 3 of 3
Thread: Car Doesnt Slow Crank With WD-40...
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    Exclamation Car Doesnt Slow Crank With WD-40...
    hey guy's my car hs a slow cranking problem..
    i sprayed some WD-40 on the terminals... and it's fixed it.... for now...
    so what do you think it could be??
    just wondering what voltage the battery should be pumping out when starting it...?
    vt v8
    Jul 2009
    clean your battery terminals and check the wire on the stater motor soleniod it might be losse
    vp series 2
    Jul 2009
    Default slow cranking
    Quote Originally Posted by S2_VR_ View Post
    A battery in good condition should hold 10v across the battery terminals, provided no other probs like starter motor or other electrics. Check battery terminals for corrosion and tightness. If you dont possess a multimeter, then get someone to crank engine and you feel the battery terminals. If hot - hi resistance present between terminal and post or lead into terminal and will require cleaning/tightening/replacing. Suss this out and get back to us if problem persists. Regards Col.
  1. very slow crank when hot
    By Berlinarator in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2009, 12:09 PM
  2. slow vr v8
    By kingrat502 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 12:21 AM
  3. Slow top end
    By Noy in forum V8 Development and Modification
    Last Post: 08-03-2009, 07:04 PM
  4. JC going slow !!
    By dijm8 in forum Site Feedback / Site Problems
    Last Post: 11-05-2008, 04:03 PM
  5. slow
    By burnz in forum Site Feedback / Site Problems
    Last Post: 27-01-2007, 10:19 PM
