Results 1 to 11 of 11
Thread: water noise behind dash
    VY Executive
    Jul 2009
    Default water noise behind dash
    when im driving my car sometimes i will notice this water bubbling noise behind the dash and im a tad concerned as to what this could be. it doesn't happen all the time and the car isn't running hot when i hear the noise, so im fairly sure its not an overheating issue. i had the radiator replaced about a year ago which i thought might have been the problem because the car was overheating but the noise has still persisted. i also noticed that sometimes there is a fine cold mist coming out of the aircon vents. could this be related?
    car is a 1995 VS berlina. any help would be greatly appreciated.
    E46 M3
    Jun 2009
    your cooling system has air trapped in it... you need to bleed the air out
    VY Executive
    Jul 2009
    is that to fix the fine mist or the bubble noise? or both? and how would i go about bleeding the air out?
    E46 M3
    Jun 2009
    bleed will fix the bubble/water flowing noise, cold mist is probably nothing (just due to cold weather coming through ya vents)
    to bleed, go outside, unscrew your plastic engine cover and remove it, start your car and let it idle in park, unscrew the bleeder valve (located on top of ya thermostat housing (the thing your top radiator hose connects to on the engine)). let it run for a fair while until your car heats up and the thermostat opens (you wont see this happen coz its inside the housing, but you'll know its open when a significant amount of fluid starts coming out of the bleeder valve hole). when you get a solid stream of coolant coming out of the bleeder valve hole with no bubbles/air at all, then screw the valve closed and your done.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The mist you mention may be coming from a leak in the heater matrix/radiator. If it smells a bit 'sickly' (due to glycol coolant) and you are needing to top up the coolant it could point to this unit leaking...not uncommon.
    Otherwise it's as in the previous posts....bleed the system.
    VY Executive
    Jul 2009
    well i bled the system. waited for a constant flow of coolant to come out. will just have to wait and see if the noise persists or not. thanks heaps for the advice though
    VX L67, ln106 hilux, xr600r
    Jun 2009
    qld
    i reckon your drain for you a/con thingy is blocked, had the same problem with my vr, eventually got to the stage that the passenger side carpet around the gearbox tunnel had a trickle of water run over it, there is a drain hole under the car just in front of the where the gearstick is, slightly to the passenger side (easier to reach from the passenger side) prod that hole with a zip tie a few times and watch the water piss out! i am positive this is in the gregory's manual as well? let me know how you go!
    E46 M3
    Jun 2009
    Quote Originally Posted by Force88 View Post
    i reckon it'll do the trick... let us know
    vr statesman 5.0
    Jan 2009
    i have the exact same problem in my vr stato.so that info is very helpful just couldnt be ****ed making a thread on it lol
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    i had the same problem with my vr when i put the ecotec in it bleed it up all good
    1998 vs s3 ute
    Jul 2009
    near blacktown
    same problem hear
  1. Water sound from behind the dash
    By vsdeath in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 08:02 PM
  2. water noise behind dash?
    By GH05T in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2008, 10:44 PM
  3. Water noise from dash, i think!
    By dazza33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2008, 09:32 AM
  4. water noise when starting
    By BobEddie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 11:18 AM
  5. Water in sill under doors, sloshing noise
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2005, 11:10 AM
