Results 1 to 9 of 9
Thread: heater no hot air
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
    Default heater no hot air
    got no hot air coming through heater only cold fan air any one able to give me some ideas how to fix this its cold at night and in the morn and cold in my car help please would be great its vs v6 ecotec
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It is probably due to the heater tap (valve) not opening due to it being seized or not having any vacuum to it. The heater tap is in the engine bay on the driver's side, it has 4 hoses connected to it and a thin vacuum hose at the top.
    MY RIDE
    E46 M3
    Jun 2009
    as mentioned, check the little vacuum hose is connected and not perished
    not an expensive part if you need to replace the whole tap... pull it up out of its bracket, disconnect hoses and lines, connect hoses and lines to new tap and place it back in its bracket. not a bad idea to replace all the hoses while your there either.
    you'll lose some coolant tho so will have to top up and re-bleed the system aswell
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    ^^^agreeed heater tap.
    Once a week I run the heater up and down to keep tap from being seized.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    vs executive
    Jul 2009
    phillip island
    VS Series II
    Nov 2007
    Newcastle
    vs executive
    Jul 2009
    phillip island
    VS Series II
    Nov 2007
    Newcastle
    vs executive
    Jul 2009
    phillip island
    cheers any one else know how much and where if cheaper
  1. Vs heater
    By northysvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2009, 11:25 PM
  2. VP heater not going
    By dslegend in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2009, 06:10 AM
  3. VN V6 S1 Heater Tap
    By Bugsy27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2009, 11:05 PM
  4. Heater tap - anyone know?
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2007, 02:05 PM
  5. air con/heater fan
    By Bunjey in forum Electrical Wiring / Questions
    Last Post: 06-03-2007, 10:17 AM
