Results 1 to 7 of 7
Thread: lower control arm problems
    jashdown91 is offline Jashdown?
    VS Acclaim S1
    Nov 2008
    live in ballina, thats near byron bay, everyone knows where byron bay is
    Default lower control arm problems
    ok ive jacked my car up to take out the rear springs to change them. i lowered the control arm by taking out the bolt connecting it to the axle. but now im trying to get the control arm back in by jacking it up, but the whole for the bolt to slide through will not line up at all.
    can anyone help with this pain in the arse problem?
    VS V8 Berlina Wagon
    Jul 2006
    it would of been easier to undo the shock from the mount on the diff, bit of pushing and shoving will do the trick though
    VS Acclaim S1
    Nov 2008
    Quote Originally Posted by Asmodai78 View Post
    yeah, well i got it all back together, had to pull the whole spring out then push the arm back in and then clamp the srping right down and shove it back in, a lot of of stuffing around, but i did it better than what the book reckons, hahaha
    VS Acclaim S1
    Nov 2008
    ok i have new problem. wondering if someone can tell me a secret to how its done.
    how the f*** do you undo a spring clamp once the spring is out of the car..
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Wind the bolt in an anticlockwise direction. It will be awkward because you have to hold the spring.
    Visit my Facebook page
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    easy, just unwind them with a shifter
    Reaper
    VS Acclaim S1
    Nov 2008
    haha yeah, i tried unwinding, but the clamp was so tight i couldnt undo it without the spring rolling away, haha and the vice on the bench wasnt strong enough.
    i ended up jacking my car up higher and putting the spring under the back wheel and lowering the car on it, haha acted as a vice. bit dodgy but it worked.
  1. Need new lower control arms
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2009, 12:23 AM
  2. Lower control arms
    By dawg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2008, 03:30 PM
  3. Lower control arms
    By commodore2004 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2006, 02:27 PM
  4. Any difference in the lower control arm?
    By dogg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 12:50 PM
