Results 1 to 6 of 6
Thread: VR. Slipping in first and reverse when cold.
    Subaru Impreza MY05 WRX STi
    Mar 2009
    Sunbury
    Default VR. Slipping in first and reverse when cold.
    Tried seaching for this but couldn't find anything.
    When I start my car up and it's cold it slips in both reverse and first. Revs up to 3 grand but doesn't go over 20kms... It's fine once it warms up though.. Any ideas?
    VR-S series II
    Jul 2009
    Darwin
    Post
    Im no expert but check trans fluid wait till its fairly warm and check it should be at the HOT mark, if trans fluid is fine maybe get it serviced. Theres heaps of people on here who know more then me hopefully someone can help ya but check the trans fluid first all the best.
    '95 vr executive wagon
    May 2009
    Launnie
    yer man,i got a vr and mine use 2 do that every morning,so i checked the trans fluid and it was low as so i topped it up and now in the last 2 months its only done it ounce so check it and if it needs it top it up but DONT OVER FILL IT!!!!!
    Mar 2009
    Sunbury
    VR Sedan
    Jul 2009
    Smile
    Quote Originally Posted by clazzza commy View Post
    Get it warmed up and keep it running before you check the level
    May 2009
    Launnie
    yer gregoris says drive a minimum of 24ks and move the selector rite through all the gears and select park(while still idling) on level ground,then check the fluid
  1. Reverse lights not working on reverse
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:02 PM
  2. only Reverse gear slipping on auto
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-09-2008, 01:40 PM
  3. auto slipping when cold
    By dmoate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2008, 01:45 PM
  4. No reverse when cold with VN v8 t700
    By v8slrtorana in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2007, 07:45 PM
  5. slipping in reverse ?
    By aurace in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2007, 12:21 AM
